So.Cal.914
Jan 31 2007, 02:34 PM
Continued from Cooltimes thread (Thanks Mike) How about it Doc?
dr914@autoatlanta.com
Jan 31 2007, 02:51 PM
QUOTE(So.Cal.914 @ Jan 31 2007, 12:34 PM)
The key is extremely hard to turn in the lock cylinder and locking and unlocking is virtually impossible! I know that is the right key though! What can I do??
John
Jan 31 2007, 02:59 PM
You could try squirting some penetrating oil into the lock cylinder to loosen up the hardened factory applied grease.
Phoenix914
Jan 31 2007, 03:02 PM
QUOTE(dr914@autoatlanta.com @ Jan 31 2007, 03:51 PM)
I don't know the answer, but sure would like to. I have this problem with both doors to an extent.
Jan 31 2007, 03:04 PM
QUOTE(John @ Jan 31 2007, 12:59 PM)
nope won't help
r_towle
Give me the keys for the 916, I will fix the lock.
Its cause you spend way way way to much time looking at those cars, and not enought time driving them...
Really, I can help.
Rich
John
Jan 31 2007, 03:09 PM
QUOTE(dr914@autoatlanta.com @ Jan 31 2007, 01:04 PM)
nope won't help
which lock?
if it's a door lock, to make the key lock/unlock nicely, it is common to clean and re-lubricate the lock mech inside the door. They get sticky over time.
Note:
This would not apply to trunk locks, glove box locks, front trunk locks, or ignition locks.
Jan 31 2007, 03:13 PM
QUOTE(r_towle @ Jan 31 2007, 01:04 PM)
Really, I can help.
Rich
sort of like my xke convt. The best way to enjoy that car is to look at it. Enjoyment is CERTAINLY NOT in the driving!
Jan 31 2007, 03:15 PM
Before we go any further I will have to admit that I am CHEATING!!!!!! I am looking in this book for all of the questions!!!!!!!!!
Jan 31 2007, 03:16 PM
QUOTE(John @ Jan 31 2007, 01:09 PM)
nope won't help
which lock?
Note:
close enough! The latching mechanism inside the door has a slider on it that moves up and down to lock and unlock, the small door latch cam on the end of the cylinder moving it up and down. It gets dirty and takes way too much force to move finally resulting in the end of the cylinder rounding off in the cam. To make the car lock and unlock easily simply remove the door panel remove the latching mechanism, clean with brake clean and lube with penetrant that turns to grease, working the sliding mechanism (looks like a c) until smooth. You will not believe the difference!
Rand
Jan 31 2007, 03:18 PM
I really love this trivia thread. Great stuff. The only thing that snags me a little about it is..... There are a ton of real-world actual problems in the garage that could use this much attention.
Don't get me wrong, and please keep this up.... But also, how 'bout we put this much effort into helping our buds solve their current/real problems?
Jan 31 2007, 03:26 PM
QUOTE(Rand @ Jan 31 2007, 01:18 PM)
good point. However As I have stated several times before I am available 24 hours a day for detailed tech advice. My number here is 770 427 2844 ext 16 My home number is 770 971 4960 and my cell number is 404 308 5652. If I do not have the 914 answer i will refer you. Please do not hesitate to call at any hour. (obviously I have to sleep but if it is important to you, call me)
Good enough??
John
That's ok George, I'm using one of these:
Jan 31 2007, 03:31 PM
QUOTE(John @ Jan 31 2007, 01:26 PM)
Click to view attachmentthank you. disgusting picture though!!!!!!!
Jan 31 2007, 03:34 PM
Suddenly everytime I drive my 2.0 it eventually dies and I coast to the side of the road. I do not hear the familier whir of the fuel pump for a second or two and the fuse on the relay board is blown. I put a new one in and it works for a few days and the then the whole thing starts over again! I know that I am not using the heater these days and the fuel pump "tests out" What the heck could be causing this problem. I now hesitate to drive my 914 because it is unreliable
Phoenix914
QUOTE(John @ Jan 31 2007, 04:26 PM)
Click to view attachmentI'll take mine with fava beans and a nice chianti.
TheCabinetmaker
Jan 31 2007, 03:37 PM
wire on aar is shorting on the block.
Rand
Jan 31 2007, 03:38 PM
QUOTE(dr914@autoatlanta.com @ Jan 31 2007, 01:26 PM)
Good enough??
No, where's the satellite hookup? Why aren't you on Discovery Channel??
Just kidding George. Please don't misinterpret my comments. Clearly you are going way beyond the call to be available for tech support. Quite amazing actually. Thank you!!!
This thread rocks. As I said, keep it up!!!
All I was saying was, it would be cool to see this much posting time/effort put into answering the unanswered actual problems posted in this forum.
Jan 31 2007, 03:48 PM
QUOTE(vsg914 @ Jan 31 2007, 01:37 PM)
very very close, and good enough! The valve itself is shorting internally. The aux air valve the heater fan and the fuel pump are on the same fuse!
Jan 31 2007, 03:50 PM
QUOTE(Rand @ Jan 31 2007, 01:38 PM)
Good enough??
All I was saying was, it would be cool to see this much posting time/effort put into answering the actual problems posted in this forum.
being who I am there are just certain things I cannot and will not answer...like: What is the best muffler for my v-8!!!!!!!!!!!!!!!!!!! I of course try to answer the appropriate questions!! (someone has to tote the line!!)
My 1.8 suddenly starts to run on three cylinders so I replace the points check the valve adjust replace the plug wire the plug and even switch the injector and just cannot figure it out! What could be the problem???
TheCabinetmaker
Jan 31 2007, 03:52 PM
QUOTE(dr914@autoatlanta.com @ Jan 31 2007, 03:48 PM)
i learned that lesson the hard way.
Rand
Jan 31 2007, 03:56 PM
I respect that. I wasn't referring the Chevy questions. I just mean let's put the real 914 questions in this forum above the hypothetical trivia. I just don't want to see the former getting buried by the latter.
I'm glad you're here. Thanks for
toting the line. Sorry for the hijack.
John
Jan 31 2007, 04:08 PM
QUOTE(dr914@autoatlanta.com @ Jan 31 2007, 01:51 PM)
Check for spark and check for fuel. To narrow down the problem.
If no fuel (or pulses to injector), check the connector, the resistor pack or even the dual relay.
Jan 31 2007, 04:10 PM
QUOTE(John @ Jan 31 2007, 02:08 PM)
You are close there is a very specific problem here
John
Jan 31 2007, 04:13 PM
I used to just have those connectors pop right out of the injectors.
r_towle
Jan 31 2007, 04:18 PM
Injector relay pack.
Injector Ground wire
Jan 31 2007, 04:22 PM
QUOTE(John @ Jan 31 2007, 02:13 PM)
They do but usually the 1.8 have a tension wire clip to prevent that. however that is not my problem
Jan 31 2007, 04:23 PM
QUOTE(r_towle @ Jan 31 2007, 02:18 PM)
nope the relay would strand them all and the ground is specific side to side. I just cannot figure this one out. It is just one cylinder that is not working!!!! Help me
Allan
Jan 31 2007, 04:30 PM
A deformed testicle?
John
Jan 31 2007, 04:32 PM
Is it fuel or spark?
Which cylinder?
John
Jan 31 2007, 04:33 PM
You are a what?
Jan 31 2007, 04:36 PM
QUOTE(John @ Jan 31 2007, 02:32 PM)
Which cylinder?
911quest
Jan 31 2007, 04:40 PM
Which cylinder?
Jan 31 2007, 04:55 PM
What has happened is that one white wire on the resistor block has broken from its crimp knocking out a cylinder. Simply remove the block (mounted on the side of the battery stand, looks like four cigarettes in an aluminum holder) and open the crimp and recrimp. (soldering never holds well enough)
I'm back on the road again!
Jan 31 2007, 05:32 PM
I finally arrive home one night after dropping off my babe. ( I like to hit and run) I pull into the garage in my 914-6 and turn the head lights of but instead of parking they continue to cycle up and down for a minute or so. Suspecting a short I remove the positive battery cable. Yet the next night they do the same thing. Please what has happened here??
Twystd1
Jan 31 2007, 05:49 PM
Ate too much acid???
C
Jan 31 2007, 05:59 PM
QUOTE(Twystd1 @ Jan 31 2007, 03:49 PM)
C
yeah that is why I have dedicated my life to the 914 happened right after I left Woodstock.
sean_v8_914
Jan 31 2007, 07:48 PM
dirty headlight motor fuse
cooltimes
Jan 31 2007, 08:01 PM
QUOTE(dr914@autoatlanta.com @ Jan 31 2007, 05:32 PM)
Headlight switch circuit has to make a contact inside the relay to signal the headlight motor to retract. I would then say the switch is bad since it feeds the relay.
URY914
Jan 31 2007, 08:06 PM
Check your ground wire that is on the headlight harness.
John
Jan 31 2007, 08:08 PM
QUOTE(dr914@autoatlanta.com @ Jan 31 2007, 02:55 PM)
In my first reply, I mentioned to check the resistor pack.
John
Jan 31 2007, 08:21 PM
QUOTE(dr914@autoatlanta.com @ Jan 31 2007, 03:32 PM)
bad diode(s) or problem with motor circuit
Pat Garvey
Jan 31 2007, 08:26 PM
QUOTE(dr914@autoatlanta.com @ Jan 31 2007, 06:59 PM)
C
Oh yeah - Woodstock. Would loved to have been there, but Uncle Sugar thought I should be elsewhere! What the hell, i would have just gotten screwed up & ..... wait a minute, I did that anyway!
Just kidding! Two years later a 914 entered my life & has never left.
Still, wish I'd had the chance for Woodstock! The mud, the diarehea, the drugs, the babes, the cops, the music, the mud - wait, I'm repeating myself. Are you sure I wasn't there?
sean_v8_914
Feb 1 2007, 09:56 AM
OK doc...whats the answer. my car was doing this but it healed itself
Feb 1 2007, 10:24 AM
It seems to be a problem only with the 70 and 71 models
michel richard
Feb 1 2007, 10:25 AM
You should'nt remove the positive battery cable without first removing the ground battery cable. Now, we all know you are a careful mechanic, so what you did, of course, is completely disconnect the battery. This being said, I dunno what the problem is . . . : - )
Feb 1 2007, 10:31 AM
QUOTE(michel richard @ Feb 1 2007, 08:25 AM)
The scenerio here is that I am a knucklehead and need advice (and that may or may not be true!!!!!!) thank you for that tip!!!!!
nomore9one4
Feb 1 2007, 10:58 AM
QUOTE(dr914@autoatlanta.com @ Feb 1 2007, 08:31 AM)
I say,you are not a knucklehead and you get back in the 914-6, you go back to see the girlfriend and give her a good
and worry about the headlights in the morning!
nomore9one4
Feb 1 2007, 11:00 AM
So Doc, Tell me what i've won!
