degreeoff
Feb 25 2007, 05:39 PM
Looking at buying the setup (backing plates inards and cables)
#1 is 150 a good price and #2 will I need the cables or will mine from the 4 work??
Thanks for the VAST knowledge here @ the WORLD of 914's
ClayPerrine
Feb 25 2007, 05:43 PM
QUOTE(degreeoff @ Feb 25 2007, 05:39 PM)
If all the pieces are there, then it can be a good price. I got a set off ebay for 50.00, but I was lucky.
You can't use the factory cables from either the 911 or the 914. You have to have a set made. I use a local boat shop.
Eric_Shea
Feb 25 2007, 05:44 PM
I think around $100 is a decent buy. Less is better... more is, OK.
You'll need to have custom cables made up.
Aaron Cox
Feb 25 2007, 06:33 PM
i paid 50 for my ebrakes...
John
Feb 25 2007, 09:53 PM
Mine use factory 914/4 e-brake cables.
$150 is an ok price as long as you do get all the parts. I paid $150 for a pair of 911 trailing arms with the hubs.
dflesburg
Feb 26 2007, 05:52 AM
I just spent yesterday working on mine.
Paid $40 for the e-brake assmblys.
Bought NEW 914-4 cables from PelParts.
Dont forget you will need rotors that work with these.
Also some calipers to fit those rotors. Of course there are some on ebay for cheap now that I got some.
Good luck.
degreeoff
Feb 26 2007, 08:19 AM
I have I believe SC rotors and calipers...they are vented and was told I would need to space them (EDIT the calipers) with a washer or two....aren't all 911 rotors compatible??
Eric_Shea
Feb 26 2007, 09:37 AM
70 to 84
dflesburg
Feb 26 2007, 01:05 PM
see my brothers blog...
blog by john
he is the man!
turbo914v8
Feb 26 2007, 02:16 PM
QUOTE(dflesburg @ Feb 26 2007, 02:05 PM)
blog by john
he is the man!
I paid $200 for mine from a club member, but I also got the 5 bolt hub to with it. The shoes look to be new and no rust to be found anywhere. So I think you are getting a good deal.
sj914
Feb 26 2007, 02:20 PM
I paid 80 shipped for a complete pair of trailing arms.
dflesburg
Mar 4 2007, 04:58 PM
Got one side done!
Lots more work that described in all previous threads.
Have to hand it to those who did this mod!
Some things....
1. must grind and cut trailing arm to make brake assm fit (four places)
2. remove one bolt location for dust cover
3. move anchor for line
4. weld on mount location for pivot bolt
5. fab and weld on backing mount for ebrakes
6. slot bolt holes for four mounting bolts
Good Luck!
Aaron Cox
Mar 4 2007, 05:26 PM
thats basically what is described in all the articles :shrug:
its on the agenda....
PRS914-6
Mar 4 2007, 05:58 PM
QUOTE(Eric_Shea @ Feb 26 2007, 07:37 AM)
70 to 84
84 rear rotors jump in width from 20 to 24 mm
