Doug Leggins
Nov 28 2003, 08:29 AM
I'm trying to incorporate potential future upgrade steps into my 73 rebuild.
Is it possible to safely use 4 lug wheels on an early 4 lug hub that has been drilled to a 5 lug pattern.
If this can be done now, it will save this conversion step when/if I convert to a 5 lug set up in the future.
thanks
redshift
Nov 28 2003, 08:31 AM
Other people may know something I don't, but I wouldn't do that.
And after thinking a minute, I can't see why you would, because you have to take them off to press studs in anyhow.
M
Malmz
Nov 28 2003, 10:10 AM
One of the holes would be cleaned out in prep for the pressed stud, and usually, if they are prepped for 5 lug they will have all the studs in them which you wouldn't want to pull.
Either:
A. Pick up a set of non-modified 4 lug hubs for temp use*, or
B. Pick up some Cookie cutters or other inexpensive wheel to run on the back until you are ready to buy your final set of wheels.
*keep in mind you will be buying wheel bearings anytime you swap these out.
sm
Joe Bob
Nov 28 2003, 10:32 AM
There are really CHEAP five lug steel wheels you can use in the interim.....I have a set rusting on the side of the house....
