4 lug wheels, On a drilled 5 lug hub? |
Doug Leggins |
Nov 28 2003, 08:29 AM
Senior Member Group: Benefactors Posts: 1,358 Joined: 6-February 03 From: Nashville, Indiana Member No.: 261 Region Association: None |
I'm trying to incorporate potential future upgrade steps into my 73 rebuild.
Is it possible to safely use 4 lug wheels on an early 4 lug hub that has been drilled to a 5 lug pattern. If this can be done now, it will save this conversion step when/if I convert to a 5 lug set up in the future. thanks |
redshift |
Nov 28 2003, 08:31 AM
Other people may know something I don't, but I wouldn't do that.
And after thinking a minute, I can't see why you would, because you have to take them off to press studs in anyhow. M |
Malmz |
Nov 28 2003, 10:10 AM
CSOBOSC founding member Group: Benefactors Posts: 489 Joined: 22-April 03 From: So. Cal Member No.: 602 |
One of the holes would be cleaned out in prep for the pressed stud, and usually, if they are prepped for 5 lug they will have all the studs in them which you wouldn't want to pull.
Either: A. Pick up a set of non-modified 4 lug hubs for temp use*, or B. Pick up some Cookie cutters or other inexpensive wheel to run on the back until you are ready to buy your final set of wheels. *keep in mind you will be buying wheel bearings anytime you swap these out. sm |
Joe Bob |
Nov 28 2003, 10:32 AM
There are really CHEAP five lug steel wheels you can use in the interim.....I have a set rusting on the side of the house....
Lo-Fi Version | Time is now: 6th May 2024 - 07:31 PM |
