QUOTE(George H. @ Mar 18 2007, 04:37 PM)
if not this what?
George - I've used this Forever Black on my other car's rubber bits which are the smooth shiny surface, but wouldn't use it on the 914 bumper tops except for a a "rough" DD, cuz they're more of a textured surface.
I also won't use Armour All guys & gals - because it builds up a sticky surface that stays & gums up & collects road crud! I used to use it on the interior smooth vinyl, but you should see my friggin visors inside after the Armour All sat for 24+ years!
These were made with a closed cell urethane foam (sometimes not so "closed cell") with a synthetic rubber type color/sealant. So I can see NO reason to sand them, as you'll just open up the cells (more) & allow even more moisture inside to rust up the carbon steel bits inside & cause more of that doofus dimpling across the top.
Use a good rubber safe cleaner, & something like Wurth or Meguires or similar high quality rubber care/preservative suitable for natural & synthetic rubbers. If you have some discoloration, then don't sand it - use one of the tire coloring compounds, but wipe off asap to avoid the overly shiny finish, then preservative.
