QUOTE(JamesBernard @ Mar 21 2007, 08:45 PM)
Hello again,
I was wondering about putting a little more power into my 76 2.0L, the car hasnt had any engine work done to it in a long while. I was thinking about putting a new exhuast, air filter, and a big bore kit. But whats your experience with these? Whats the best way to go without doing any type of 914-6 or V8 conversions? I'm in the process of restoring/getting the car painted so this will all come later, i was just looking into it.
Thanks for all the help!
Back to your original question.... Sounds like you want to do exactly what I wanted to do when I started my project on my '76. I did the euro-piston kit, and early 2.0 exhaust, w/bursch muffler.
I didn't plan on separating the case and getting to the cam, but I could SEE the wear pattern on the lobes, so I bit the bullet and did the cam as well. Then, while I was in there, I checked the crank, had the journals micro-polished, and installed new bearings all around. These are minor costs as long as you're doing the cam.
I bought the new pistons/cylinders at EBS Racing, as well as their 2.0 rebuild kit, which included new valve guides and new rod bushings. In the end, I shipped the guides and bushings back along with the heads and had them do the heads as well.
My SSI exhaust ('76 conversion kit) and the Bursch muffler are from AA. I didn't know about Racer Chris or Tangerine or any of that stuff, which certainly warrants a look these days....
Originally, I was planning on going to a K&N air filter, but did some research, and decided not to. Too many reports of them not being as effective a filter, and only minor reduction in restriction.
The engine pulls noticeably stronger, mostly due to (I think) the new exhaust. The combined effects of 8.0:1 compression, new cam, a fresh rebuild add up, but I suspect each alone is kind of minimal.
I went with a cam that is only a few degrees more aggressive than stock, timing-wise, but with higher lift. I'm using the stock D-Jet, and it's idling and running fine, although I still need to fine-tune the MPS this season.
The place to really focus, research-wise, is on the cam. You can't easily change that later. Some people can do it in a weekend, but that wasn't my goal- I never ever want to take the engine out of the car again, muchless separate the case. I would certainly defer to the experience of 914.world and take a close look at Jake's family of cams......
Also, since my car was running fine before, I spent a few years collecting the parts. I watched for year-end sales, like at EBS and AA, eBay, etc, and saved a bunch of money. For some reason parts are more expensive when the car is apart than when you're still enjoying it on the road. Plus, things are getting discontinued at such a rate that snaring them while you can, and having them on the shelf, sure feels good later when you need them!
Good luck!
