"Hmmm, maybe today the red flag would be "absolutely no rust."
Paul
Well, that is always a clue that a 914 may not be as described, but in this case, it is a very appropriate description! I just got back to the desk after spending an eight hour day getting to Fort Myers, inspecting the Olympic Blue L51P 914 2.0, and fighting the homeward bound Miamian's, who, after a full week, are quite the match for most of us Porsche driver's! You haven't lived until you have beat a smoking 84 Ford Econoline to the entrance of the Sunpass Booth!!! And don't EVER make the mistake of slowing down to the recommended 25 mph to transit the said Sunpass Booth... these nut cases WILL hit you in the rear and push your a.. right thru and into the next world!!!
In any case, I survived, and am here to report that this is the finest 71K mile original 914 2.0 that I have ever had the pleasure of shifting gears in! The Seller has "Underrepresented" the car in most every respect except for the set of very good photos.
Let there be absolutely NO doubt (and I have no affiliation with the Seller in any respect), the Olympic Blue Paint on this car is "Original", as was applied at the Karmann factory. It is in very good overall condition for a 34 year old car, of any brand. I found no evidence of a repaint on any body panel. It does have three minor (to my judgment) "Nicks"... two are about 1/2 to 1" long "Breaks" in the paint on the passenger side rear fender just below the sail panel. One is obviously a ding probably from an errant car door, but it did not dent the metal, just nicked the outer paint layer. The other is also a very small circular ding that caused a small crack in the surface paint, but did not remove the paint or leave a dent. The third is a small 1" scratch on the edge of the front passenger wheel well, which removed the surface layer of paint. The paint is overall smooth and has a nice gloss, which could probably be somewhat improved by careful cleaning and waxing, but absolutely DOES NOT require a repaint of any sort. In fact, it would probably be best to just wax the paint to maintain it rather than try to bring it to any sort of "show car" finish. Bumper Tops and Chrome are all very good. Top and all weather strips are excellent (may be newer?). Lights and Turn Signal Lenses look very good...and correct for the car.
As to rust, this is as close to a "Rust Free" driven 914 as you will ever find. The fender wells, jack points, belly pans, suspension consols, firewall, etc. etc. are all very very nice and show only the most minor of surface staining. Most of this can be clearly seen in the ad photos. I could find no evidence of any rusting in the longs, or in the door jambs, or under the doors, or even in the dreaded Rear Trunk area, and this even with the original foam rubber mat still in place, which holds water like the sponge that it is. What that means is the car just was not exposed to water, in any form! Or even any serious condensation, for that matter!
The "Hell Hole" looks very good also, top and bottom. The only deterioration is, as usual, the battery tray, which has begun to give up its original paint due to battery acid. Photo attached below. However, I believe even this tray could be easily rescued with a bit of cleaning and a POR treatment, and then repainted the correct Olympic Blue, which is really a nice color for this car. The battery console appears to be untouched by the Acid Bug, and as such will not require replacement.
The other amazing item is that BOTH of the rear trunk hinges are original and have not been rewelded!!! And appear to function as new, with the original nylon rollers. A set of nice Bronze rollers would probably be a good idea tho.
Interior: Again, very very nice... Drivers Seat outside bolster has a 1" pull out in the corner seam. I would be inclined to not repair it as such, but to simply insert a small vinyl patch thru the slit, as this is not a high stress area, and would be more in keeping with the overall originality of the car. The Center Console has it's edges capped with non stock aluminum channel; obviously a home job, but not horrible... makes one wonder what is underneath, but I did not explore that far. The door panels look to be original, but have succumbed to the dreaded Stereo Worm.. both panels have BIG speakers installed. Anyone have a NOS set of 73/74 Door Panels lying about! The Stereo is nice and plays well, but... not in MY 914 2.0. Guess that is just a personal thing. At least the original speaker boxes are there and in great shape. The Leather Steering Wheel needs replaced or rebuilt, and of course, there are sources to rebuild it... as "Must Do" IMHO. And she needs a set of door seals; well to be expected; the remainder of the interior seals seem good. The outside window seals along the door tops have shrunk; replace these as well. Interestingly, the tabs at the rear of each door window look very good... I suspect someone already got a set of these from AA; they don't look quite original to me, but do the job fine. Instruments appeared to work, with exception of Temp gauge... did not see a reading on it during a fifteen minute drive. Gas Gauge may be a bit off...
Other than those relatively minor issues, the interior is top notch... pulled the carpets and not one sign of "rust bugs" anywhere! Even behind the seats are clean dry and original... The original carpet is in super nice shape, and the german square weave carpet mats on top are also a great period touch, although they really look like they would go better in a 356... frankly, I don't ever recall seeing these mats in a 914, but they just LOOK so right! Dealer Option, I suppose.
The car has a full set of Fuchs 2.0's, plus one, so the buyer gets six... can't have enough Fuchs! All in very good shape, and do not require any refinishing, except for the center caps... all need refurbished, or replace them with a set of billet caps? Hate to do that on such a very original car... guess it's time to find a good metal worker!
Front trunk has a mounted fire extinguisher, and a funky little 12V light to see by when you are changing your tires in the dark! Both home installed, but they somehow add to the uniqueness of this time capsule, and we all know that a fire extinguisher is always a good idea in a Teener. BTW, the chassis numbers on the fender tab and the data plate match the door sticker and the original Window Sticker VIN, so all appears to check out in this regard. I did not get the mirror out to check the engine number, but i would bet it matches the chassis!
Which brings me to the engine... still all original D Jet Fuel Injected!!! And... she runs great!!! Just a bit of cold start hesitancy, but warms up very quickly and runs and idles absolutely as nicely as my first 2.0 that came off the showroom floor. Great power right up to redline in every gear, and I got there in the first four, and halfway there in fifth...
And the gearbox... I have shifted more than my share of 901 boxes, and this 914 side shifter is as good as it gets. In fact, I would almost guess that the gearbox had been completely rebuilt at some recent point, but there is no evidence of such work via service records, so I just can't explain it... super smooth and the most precise box I have ever used... not a single "Snick" or "Graunch" in any gear. Just flat gets it done! Clutch also very smooth and progressive... Can't believe it's original, but again, nothing to say differently..The only service invoice is for a general redo of electrical items, including a new alternator, done at 67K miles. Some brake work also at that time... beyond that, who knows?
Click to view attachmentThe Suspension does feel like a 34 year old set of shocks... these I would definitely replace... too much "Wallow" for a 914, but after all those years, I tend to Wallow a bit myself! Brakes seem as good as most 914's... no mushiness to the peddle... a few squeaks at first, but I figured the car just hasn't been driven much.
And a last few pluses and minuses... There is a nice original Bilstein jack in the trunk; there are two 3" binders full of factory service manual copies; there are a few tools, but not a complete kit (no tow hook, etc.); there is a copy of the original Window Sticker in the back of one of the binders... Two options: Full Tinted Glass = $100.00, and Intermittent Wipers = $15.00 Full Appearance Group... Total $5,959.50... not a bad deal! I'll take two! Sold new at the Reno, NV Porsche Dealership! The original Service Record is still in the car, with the Maintenance Booklet and Dealer Listing, but no Owner's Manual. Oddly enough, a xeroxed copy of the Owner's Manual is in one of the Binders. There is a Bra in the front trunk. Some minor miscellaneous bits and pieces of spares; nothing special there.
What's it worth? Well, there are probably less than a dozen of this original condition 1973 2.0's anywhere in the country, and I suspect this one may be destined to go overseas... So, if you always wanted one of the best of the breed, now is the time to Pony Up!
