QUOTE(John @ Apr 6 2007, 12:03 AM)
QUOTE(r_towle @ Apr 5 2007, 07:47 PM)
You cannot adjust the door that way, only in and out to match the fender.
You cannot (without moving metal, or cutting rivets) move that front gap...dont look at it...ignore it.
We can however fix the back if you show me a complete pic like I was talking about...2 people (300 lbs) and non people.
Just how much would you like to wager there buddy? The front gap can be fixed just like the rear gap. As long as the opening will stay a fixed dimension, the gaps can be made fairly even. (no cutting rivets)
QUOTE(John @ Apr 6 2007, 03:22 PM)
Someone asked how this was possible. It is easy with a car with a cage (or in your case a roll bar) installed. I use a large diameter turnbuckle between the point where the roll cage/bar is bolted/welded to the long near the lower firewall and push from this anchor point to first the top hinge and then the bottom hinge. You must move slowly an in small increments to insure you don't close the front gap too far. You can easily make adjustments to the hinge post in 1/64"s. Close the door after each stretch to see how you are doing. It doesn't take much to correct the door gaps on a car that is solid. Things are a little more tricky on a car with no cage/anchor point to push from, but they can be done as well.
I could take some pictures if it would help some people to visualize this.
I asked how to move the front gap without cutting rivets or bending metal.
You have a good idea, I am sure it works, but it involves bending metal.
I am concerned that the car does not have the motor in it while you are finding the 1/32 inch movement.
I wonder if that would be more with a motor and a human...
One simple suggestion that would keep the car capable of both street and autox/track would be to add an angled bar from the roll bar (provided its bolted to the seat belt hole) and the front a-piller at your feet, where the speakers go.
This bar could be bent to allow easier access when getting in and out, yet provide some rigid strength in your problem area.
If you do this, consider one more bar going rearward to the shock tower inside the engine bay, under the lid.
In the worst case scenario, I would grind the fender, and grind the door a bit, and call it a day. Door gap grinding is quite common, and it was what I was gonna suggest...its not to hard, and if you happen to blow through the door skin on the edge, weld it up, and dress it with a grinder.
I think 3/32 is the proper door gap width, but I would personally find the largest gap on the door as it sits, and make the rest of the door match.
I would work over that fender first, grind off what you can, then take a 1*1 metal tube and a hammer and push it back just a bit more.
Then do the door, the handle will certainly move 1/32 of an inch forward.
Rich
