Wiki is cool, lots of good info as long as you have an idea of what the answer is.
Anyone can post there so you can also get a load of crap.
2 cycle and 4 cycle is apples and oranges, you can eat both but they are no where
near the same. You may get a pulse back but as you mentioned utilizing it with
valves in the way especially on the compression stroke when the exaust valve is
closed. When the exhaust valve is open the piston is on it's way up to expel
burnt gasses and then the e valve then closes as the piston heads back down
to draw fuel and then back up on it's compression stroke. The pipe from FMF has
no real restriction on the gases as you need on a two stroke. Better minds then
mine have pondered this and I still have not seen a 4 stroke that has made it work
like you can on a two stroke, IMHO I think you would be better off useing that
exhaust to drive a turbo on a 4 cycle.
But there is nothing like the feeling of a built 2 stroke when it comes up on the pipe.
Hope this makes sence to you.
