QUOTE(dr914@autoatlanta.com @ May 9 2007, 10:35 AM)
QUOTE(obscurity @ May 9 2007, 11:30 AM)
Does anyone have a picture of or a link to a lower fire wall replacement panel? I am interested what the available panels look like as it hits the longitudinal under the battery. Also who carries them?
Thanks,
John
john there of course is a lower inner and outer firewall. the outer is about five inches high and runs from one heater tube opening to the other. the inner firewall is two pieces about eight inches high and runs from the rocker panel at the lower seat belt bolt area to the middle of the center tunnel. The drivers side has the two holes for the emergency brake cables.
I replaced the inner and outer firewall recently. The inner is a piece of cake. The outer is a real PITA. I cut mine vertically to get it on over the heater pipes. Other cut it differently. One problem is with the shifter fittings. There is no lip to install the shifter boot. There is a plate welded behind the Firewall for the shift rod. This also is not included and must be removed from the old and installed. Then there are the heater cable lines, the clutch cable tube and the accelerator cable tube. I replaced all them. I had the tub on a rotisserie and replaced the floor pans. The inner firewall pieced were from RD. the rear is from AA.
