Sold my '73 2.0 and promised to fix a few things for the new owner that hopefully will be joining our ranks!
1) Turn signals don't cancel, steering wheel is NOT upside down and the cancel ring is in the right place. Do I need a new switch and where can I get one?
2) Wipers don't park. It has intermittent wipers which do not work so I'm thinking that is the culprit and it needs a new relay. Where can I get one?
3) Temp gauge is not hooked up but taco plate and temp sender are there. I know about the green/black wire, I'm sure it is under the center console but I do not see it in the engine compartment or under the car. Let's just say I want to run a whole new wire. Where can I run it so it exits the passenger compartment and goes under the car to the temp sender?
Thanks and I'm not going away, I'll still be lurking as always!
