Well I was just out there fooling around with it
. I jacked up the back end and got under and fooled around with the linkage right at the tranny and then fooled around some with the shifter up in the car....
From the tranny it seemed that I could get it into 4th or where it would be to get 4th. The rear wheels were still on the ground so i started it up and let out the clutch slowly to see if it'd choke out... nope, just like neutral
So I messed around with the linkage at the shifter and tried to get it to go further right (or left
) and front to back to see if any position would get me 4th. It seemed as though I could nudge up against 4th, but it would just slip off but it would slip into some spot. started it up again and tried to choke it out.. nope, nothing
each time I shifted it into another gear (usually 5th) to make sure it would choke out and it did, so at least i'm not crazy... right?
