Hi , Is the fan on the front of the engine that also runs the alternator the same for all size engines, I have one from a 1.7, will this fit a 1.8 or 2.0 . I think there all the same,but wanted to check here first. Dave
Joe Ricard
Jun 20 2007, 05:50 AM
Any fan will fin any motor. there are different bolt for the early one Allen bolts vs. hex head.
SLITS
Jun 20 2007, 11:34 AM
And to add ... It is possible that there are different timing marks on them. A 1.7 and 2.0 should be marked the same. The 1.8 will be marked differently.
That said, you should mark your own or at least check the one you install for the correct timing marks.
JoeSharp
Jun 20 2007, 11:36 AM
Dave: I've seen bus fans with no markings and it fit. I think they all fit.
SLITS
Jun 20 2007, 11:40 AM
QUOTE(Joe Sharp @ Jun 20 2007, 10:36 AM)
Hey Joe, I thought the bus fans were marked with paint on the belt rim.
JoeSharp
Jun 20 2007, 05:04 PM
That would explane why I saw a fan with no markings.
BarberDave
Jun 20 2007, 07:46 PM
Bumpy
Dave
