I did some measuring & didn't find a PVC pipe/fitting that would give optimal results (off the shelf). But, with a little shaving... it should be do-able with just a couple minutes of filing.
When I get the stuff... I'll report back with effectiveness/fit.
I ordered some parts from
www.flexpvc.comTotal came to $19.74 delivered.
To knock cap out of rim, I ordered:1.5" Class 200 pipe (1 foot): OD: 1.900" wall thickness: 0.090"
Product ID:
CL200-015I think I'll have to shave a fuzz off the ID... so it will sit fully in the annular ring... for knocking it out without pushing on the central flat area.
(Schedule 40 or 80 pipe can be used (same OD)... but would require more shaving on the ID, to prevent pushing (at all) on the central flat area.)
1.5" cap... to tap against.
Product ID:
447-015To seat cap in rim, I ordered:2.5" Schedule 80 pipe (1 foot): OD: (doesn't matter) ID: 2.290"
Product ID:
Sch80-025I'll have to shave a little off the ID and probably bevel the bottom edge slightly, as the cap outer lip is not perfectly flat.
2.5" cap... to tap against.
Product ID:
447-025
