Here's a little something for the 3.2 Motronic conversion projects out there.
A complete wiring diagram to adapt a factory /6 to a 3.2 Motronic. If you want to use it on a /4 chassis, you can by moving some of the pins in the connector to the harness. This also eliminates the relay board, and adds a fuse box for the Motronic.
I know this harness will work, I built it for a 3.2 engine in a factory six. Everything works, including the temp gauge in the dash, the charge light, and the oil pressure light.
I intend to redraw the diagram for the /4 chassis, but I have not finished it yet.
