Full Version: New electronic stuff on EEEEvil Bay
Steve Thacker
Anyone have any knowledge about this new gadget?
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...5525&rd=1,1
Brian Mifsud
It stinks of "Made in China".. otherwise a knockoff of Pertronix.. I don't see any innovation in their ads.
Steve Thacker
I did some digging and the samba folks are trying them out.
Another site http://www.itinerant-air-cooled.com/viewtopic.php?p=30151
I think they have thrown the towel in. even thought they mentioned that the people who make these
http://www.hot-spark.com/Hot-Spark-SVDA-034-BOS4V1.htm have good customer service.
I'm buying a Petronix and going to sell my crane optical if all goes well.
BarberDave
Steve :
I'v had a Pertronix since i got mine in 2000, I burnt one up a couple of yrs, ago. My fault ,not the unit, installed another , 2rs ago I love it.
Why are you getting rid of the Crane?? I was under the impression that it was a up grade from the Petronix. Not suppose to burn out if you leave the key on like the Petronix. That's what I did. Am I wrong??? Dave slap.gif
Steve Thacker
Dave,
I have to finally admit, that I'm dumb and dumber with this Crane unit. I get it to idle like a champ and it runs nice, but it falls on its face if I try and push it to the floor quickly. I have new everything ( injectors, fuel set for 28lbs, fuel regulator, sparkys, plug wires, fresh valve adjust) I could just go on and on. oh ya checked and the timing is dead balls on. I have no clue why this is not working as it should. so, the next logical strep is to replace the optical and try the Petronix II. If it goes well then I'll sell the Crane " XR-700 fireball" and move on.
Cap'n Krusty
It doesn't sound like a "Crane" problem. You get the correct one for your distributor? Your vacuum advance/retard can working correctly? Your mechanical advance working properly? All of those can be tested with a timing light and perhaps a Mighty Vac.
The Cap'n
Twystd1
Throw a set of points in and see if it makes a difference.
Clayton
ahdoman
QUOTE(Steve Thacker @ Jul 13 2007, 12:14 PM) *
Don't do it! I'm on my second one! They can't take the heat generated by our engines. Mine runs great until it heats up then it all goes bad.
