QUOTE(toon1 @ Jul 17 2007, 11:55 AM)
put in a Raby type IV and you'll have a nice car!
It's got the wrong engine mounts for a type IV...
QUOTE(McMark @ Jul 17 2007, 04:03 PM)
That looks great! So this is an acid dip car? Was it done at the same place as the e-coat? Is the e-coat supposed to cover the inside of the longs/etc? What prep is necessary before paint?
You're a pioneer!
Yep, the same place did the acid dip. The E-coat goes inside all the box sections and inaccessible areas - that's why I had it done. A fair amount of the outside coat will be lost when it gets the skim of filler over the wings. I've got to replace the LHS engine bay side panel and a tiny section of inner wing at the bottom of where the oil tank sits as well so that bit won't be coated.
The whole process isn't cheap, at the moment it'd work out at about $4000 for a 914. There was a real GT40 going through when I was there, and loads of big old Mopars and Fords lying about the place - apparently they get cars from all over the world.
I'm not sure about pre-paint prep - I believe it can be painted over
