I'm getting so frustrated, I'm ready to pull out the 12 ga and go to town on this friggin car
I replaced the pedel assembly today, two hours because one of the mounting bolts on the pedal base was shorter then the other by way to much. Cable are all hooed up, it fires right up and shifts fine.
Here is my problem.
All the hoses are hooed up I pou in the brake fluid and it comes right back out. I checked the brakes lines, all hooked up, feed lines coming into the M/C are fine. It appears to be coming from the front of the M/C, where the piston rod goes in.
Is this common, do I need to open all the lines up at the wheels?
