I think my high beam relay is failing. Last night the high beams stayed on and would not go off. I did not hear the relay switching. About a week ago, it wouldn't switch to high beams. In between it worked fine. Any advice on dissecting the relay and if it's not fixable, where to get a new one. Will this one work? It's the same part (111 941 583).
Second issue is that when the key is out of the ignition, activating the directional stalk either right or left will turn on the corresponding turn signals (front and back). Is this supposed to happen?
