Bogaat
Oct 2 2007, 04:33 PM
I am finally starting to make some progress. I have the engine all built (stock 2.0 w/ the help of Jakes video) and the car painted. You can see I have the dizzy in pieces ready to be reassembled. Believe it or not, it was full of glass! Somone had obviously busted out the back glass in the middle of a tuneup. The engine was covered in it and the dizzy had chunks as well. One of the springs had popped off...no wonder it was running like junk. Where do these two pieces go? One is a cap with a flat side and the other is just a bendable piece which fits over some edge...some where. Thanks guys!
Click to view attachmentClick to view attachmentClick to view attachment
Bogaat
Oct 2 2007, 04:34 PM
Bogaat,
Looking good. Can't help with where the parts go, sorry.
If you are using the fuel inj., make sure you do a continuity check on all of the connectios while you have it out. Also check all of the wiring from the 12 pin connector at the relay board to the different places those wires go. I did mine while the engine was out and found several bad connections. Keep up the good work.
Tom
SLITS
Oct 2 2007, 06:45 PM
The long black piece is either a vacuum hose or trim for the engine grill edge.
The other round thingy appears to be the plastic plug to access the torque converter bolts. Goes in the round hole in the back of the engine case.
Bogaat
Oct 2 2007, 09:22 PM
Thanks for the reponse on the parts...both wrong though. Those pieces are all in and accounted for. Any other thoughts?
Here is the beast before I tore into it...
SLITS
Oct 2 2007, 09:35 PM
Well since the photo is dark and I can't tell relative size to anything .... and yes, I pulled it into Photoshop and tried to blow it up and lighten it.
Last two
Heater "J" tube cap off .... '74 and above with only a single feed from the blower to the HEs
Window "fuzzy" strip
So, whadda ya want for free? Throw 'em into the trash ... you don't need them.
Hammy
Oct 2 2007, 10:56 PM
How'd you get everything so clean?
effutuo101
Oct 2 2007, 11:44 PM
Bogaat
Oct 3 2007, 06:50 AM
QUOTE(Hammy @ Oct 3 2007, 12:56 AM)
Pressure wash and a trip to the powder coaters for most of it. I did paint random small items and took a wire brush to the case.
So.Cal.914
Oct 3 2007, 06:56 AM
If you can't find where they go it was probably over engineered anyway.
The long black thing does look like it covers the edge of sheetmetal somewhere.
Bogaat
Oct 3 2007, 06:58 AM
QUOTE(SLITS @ Oct 2 2007, 11:35 PM)
Last two
Thanks for the feedback. I will try to take a better pic and find parts numbers. The cap is about the size of a quarter and is threaded with a flat side on the "circle" top. The bendy strip is about a foot long. I am 99% sure it came off of the engine as it was in that pile of stuff.
type47
Oct 3 2007, 09:37 AM
the "bendy thing about a foot long" could be a piece that fits on the edge of the engine tin that is the vertical piece on the flywheel end of the engine, like an edge guard. the rubber seals in the mounts in the engine bay will touch the edges of the engine sheet metal. i think that piece is a "guard" on the end/edge of the sheet metal.
jasons
Oct 3 2007, 09:53 AM
Looks great! One small piece of advice.... Make sure you are getting a good ground between the alternator and the case. I think powdercoating the alt brackets can induce some resistance. I powdercoated all my stuff and it wasn't a problem.
Bogaat
Oct 3 2007, 09:56 AM
QUOTE(jasons @ Oct 3 2007, 11:53 AM)
Thanks man. I am good to go there...I decided against using powder on those and the shroud (used a ceramic spray paint and a spray clear coat). I have heard stories on here and decided to avoid them. I even ground the paint I put on there to be sure I was good
Demick
Oct 3 2007, 10:28 AM
Small black cap could be the cap that goes on the PCV valve (inside the oil filler box). About the size of a quarter.
Bogaat
Oct 3 2007, 10:47 AM
Bogaat
Oct 3 2007, 10:53 AM
QUOTE(Bogaat @ Oct 3 2007, 12:47 PM)
and could this be my cap? Not sure how it is supposed to fit in there...have to go home and check it out. Number 37
http://www.pelicanparts.com/PartsLookup/HT...5-05-Frame3.htm
Bogaat
Oct 3 2007, 11:06 AM
QUOTE(Demick @ Oct 3 2007, 12:28 PM)
http://www.pelicanparts.com/PartsLookup/HT...4-05-Frame3.htmTime to go home and dig...
Thanks all!
Bogaat
Oct 3 2007, 09:23 PM
#9
http://www.pelicanparts.com/PartsLookup/HT...4-05-Frame3.htmBy the part number... that seems to be it! How the heck does it attach? I haven't taken off the filler neck yet, but did the PCV. I am not seeing it. Thanks!
Demick
Oct 3 2007, 09:38 PM
It just snaps onto the bottom of the PCV valve. But it doesn't stay on very well. It's very common for them to fall off and you'll find it in the engine recess where the oil filler box sits. Luckily they can't quite get all the way into the engine.
