zen motorcycle
Oct 8 2007, 10:13 PM
I removed the longs because I just knew there would be rust in there and I was right.
How bad is it and what are the repair techniques?
Seems to be limited to just around the jack points and one other area on the right side about 3/4 of the way up where foam was touching.
start from the begining for me I did a search, but didn't come up with much for the beginner metal worker.
Thanks
More pics available, just tell me if anything would be helpfull in the treatment
Rand
Oct 8 2007, 10:56 PM
Here are a couple of my favorite threads:
michelko's:
http://www.914world.com/bbs2/index.php?showtopic=16748cdmcse's:
http://www.914world.com/bbs2/index.php?showtopic=25165Oh, and Jeff Hail recently started a great one:
http://www.914world.com/bbs2/index.php?showtopic=76791Some other key word searches that might work include: hell hole, rustoration, frame rail rust, suspension console rust
rjames
Oct 8 2007, 11:53 PM
Doesn't look much worse than mine was. It looks like a fairly easy fix, especially if you weld. If not, it just means you should learn!
Start by grinding all that rust down to bare metal to see how much metal you have left in that area.
I used a 1/4" drill with a stripping disk, and also a dremmel tool for those hard to reach areas.
After you've done this, post some more pictures and I'm sure plenty of folks will chime in with advice.
The threads that Rand posted are good ones, I studed them both long and hard before doing my repairs, even though mine weren't nearly that involved, they provided great info.
Rand
Oct 9 2007, 02:56 AM
Yes, for sure yours is no where near as bad as the other threads. I didn't mean to suggest that you would have to go through that kind of work. But great repair techniques and info therein.
I agree with Robert... Start by getting the rust off and see how extensive the damage is.
Looks to me like the whole jack plate / post needs to come off. A cutting disc on a grinder, then a grinding wheel should take care of that. The metal on the frame rail under that may not be so bad. Once that rotted metal is gone, wire wheel all the rust off and see what you have.
If you find the rust damage to the underlying metal is deep enough to threaten it's integrity severely, then you'll need to cut out the rotted metal and weld in some good sheet metal patches. There's a good chance it won't be that bad, but it's hard to tell yet.
Then treat the metal that was rusty with Ospho (or rust converter of the like).
Personally, I wouldn't bother putting another jack plate back on, but if you want to they should be readily available and you could weld a new one on.
If you add new metal, it should probably be treated with Metal Ready or another etching primer. Then paint everything with Hammerite or POR15.
tdgray
Oct 9 2007, 07:49 AM
That's not rust... sheesh... you guys are spoiled.
Seriously... that looks like an easy fix.
rhodyguy
Oct 9 2007, 09:55 AM
show us the pass side rear portion of the long. that driver's side long is no biggie at this ooint. be prepared for more heartache the deeper you go.
k
rmital
Oct 9 2007, 09:59 AM
QUOTE(tdgray @ Oct 9 2007, 09:49 AM)
brer
Oct 9 2007, 11:06 AM
I did the same repair. My blog has pictures.
easy to do, though accessing the top of the jack point for welding will be near impossible without cutting the quarter panel.
A jack point delete might make the job easier, but I chose to keep them.
You can expect to lay in a couple layers of metal at the jack point, not a big deal.
One thing I would worry about is rust inside the long. Maybe someone else has experience as to when its adviseable to open it and treat the inside?
SirAndy sprayed the inside of his with metal ready as I recall.
rmital
Oct 9 2007, 11:36 AM
QUOTE(brer @ Oct 9 2007, 01:06 PM)
A jack point delete might make the job easier....
first pic was of cut from a piece of outer shell...second was just layering metal
I was going for easier
Rand
Oct 9 2007, 12:39 PM
QUOTE(tdgray @ Oct 9 2007, 06:49 AM)
I agree. An easy fix. Compared to mine. Here's how spoiled I was:
rhcb914
Oct 9 2007, 12:54 PM
I had the same issues a couple years back. It really wasn't that difficult to repair. If you end up opening up the longs I would treat them with Por 15 or some rust preventing paint. I used an engine detail gun to reach into the longs. They are cheap from harbor freight.
http://www.harborfreight.com/cpi/ctaf/Disp...itemnumber=3953The hardest part was welding the top of the jack support. I ended up cutting the door jam to get access rather than cutting the fender. I didn't want to have to repaint the quarter pannels.
http://www.914world.com/bbs2/index.php?sho...c=27066&hl=Good luck!!
dflesburg
Oct 9 2007, 01:10 PM
Zen,
Your car is terminal, if you ship it to me along with $250 I will dispose of it properly for you.
zen motorcycle
Oct 9 2007, 04:22 PM
QUOTE(dflesburg @ Oct 9 2007, 02:10 PM)
Zen,
Funny, I bought the car from a guy in Ohio!
I knew it wasn't bad, just looking for a step by step for fixing it, Gage sheet metal to use, or if there were replacement pieces available that I could just weld in.
Thanks again guys
more to come
zen motorcycle
Oct 10 2007, 10:09 AM
What are some good resources to buy NOS or repro parts like the jack post supports or outer longs? Or do I just find a donor?
Thanks
Allan
Oct 10 2007, 10:41 AM
Do a google search for Restoration Design.
They make repro sheetmetal parts.
type11969
Oct 10 2007, 11:56 AM
Or you could just fab it all yourself using what you have left as a template and make paper templates where you need them:
http://www.914world.com/bbs2/index.php?act...f=2&t=66637Its not tough, just time consumping I suppose. What you have looks easy to repair by fabbing yourself.
-Chris
G e o r g e
Oct 10 2007, 12:06 PM
repro partsand put up a want to buy in the classifieds, you will be surprised at how many people have parts laying around
zen motorcycle
Oct 13 2007, 08:38 PM
Here comes the heart ache
Passenger side ling is not nearly as nice. I have some floor board/firewall rust as well. The POS had covered these up with pieces of tin and screws then put undercoating over it to hide it. Didn't see it till I started stripping everything
Pics of passenger side
Firewall
Click to view attachmentClick to view attachment
zen motorcycle
Oct 13 2007, 08:39 PM
Right Long underside
Click to view attachmentsupport plate. Notice the silver goo along the firewall.. not sure what that is yet, but it can't be good
zen motorcycle
Oct 13 2007, 08:41 PM
zen motorcycle
Oct 13 2007, 08:42 PM
Is there a way to get the jack post out with out cutting the quarter panel, or is that the least of my worries?
rick 918-S
Oct 13 2007, 09:31 PM
That's just a stub. It doesn't go through the long. Just use a Sawsall.
zen motorcycle
Oct 14 2007, 12:47 PM
Yeah I busted out the sawsall today, but before I go any further do I need to tie in the frame with a support bracketfrom the seat belt bolt to door hinge to keep it from flexing when I start removing material?
type11969
Oct 14 2007, 01:57 PM
I definitely would. What you have looks similar to what I had to deal with, probably a bit less extensive. Take a gander at the thread I posted above if you want to see how I dealt with the rust.
zen motorcycle
Oct 14 2007, 02:00 PM
QUOTE(type11969 @ Oct 14 2007, 02:57 PM)
I have looked through those threads you posted. What scares me the most is if I have to remove the quarter panel. If that happens I am going to take the whole care down to bare paint as there are some small rust bubbles elswhere on the car.
Hello 10 year restoration!
type11969
Oct 14 2007, 06:18 PM
You definitely don't have to remove the whole quarter panel . . . I pulled mine because someone replaced from the sail panel down on my quarter, but used rivets, braze and a generous helping of bondo to do so. You probably will have to cut a small section out like michelko (sp?) did in his repair though.
zen motorcycle
Oct 14 2007, 07:07 PM
That is what I was afraid of, I can weld ok, but nothing good enough for finishing work on butt welds. I just don't have the rig for it. It would be easier for me to remove the spot welds then cut the corner panel.
rhodyguy
Oct 14 2007, 11:17 PM
wow.
rick 918-S
Oct 14 2007, 11:28 PM
Do yourself a favor, don't start on this project without help. It looks like your in over your head.
type11969
Oct 15 2007, 07:18 AM
If you can find someone local that has been through this to help you out that would be a huge benefit, but you can do it yourself with the guidance of people and threads here. Before I tackled my 914 I had never welded before, let alone fabricated anything and while my end result probably won't be as nice as others on here, it will be strong and functional. There is no reason why you can do the same. The shapes of the 914 "frame" are not difficult to fabricate with simple tools, and most of the pieces are readily available from AA if you want to go that route.
-Chris
zen motorcycle
Oct 15 2007, 11:40 AM
type11969 thanks for the support everybody else if you have something constructive share it. I guess I should rephrase. I can weld just fine, but I don't have a good MIG welder right now. Just not in the budget so having someone else do it is definitley not in the budget. I thought removing the Q panel by drilling the spot welds would make it easier to re-weld with the rig I have. I have done metal fabrication before, just not on a 914. As others have been there and done that I am looking for any tips and tricks so I am not reinventing the rust bucket as it were. These should be simple repairs with the exception of access to the areas covered by the Q panel. If I am wrong tell me, but tell me why and how I should do it. To late to not start on it as I stripped the car last night. And why wait the rust isn't
Thanks
type11969
Oct 15 2007, 11:56 AM
You may consider cutting the quarter panel then having someone else weld it back on . . . taking the whole panel off is kind of a pain. I know I am not looking forward to putting it back on. Or you could rent a MIG when you need to weld the section of the quarter panel back on.
rhcb914
Oct 16 2007, 09:07 AM
If the rust is mostly located in the lower part of the long and the jack support you can reach all of that area by just cutting the door jam and using a mig with a small gun. Use a very thin cutoff wheel to cut the jam and drill the spot welds along the inner part of the door jam. You can see what I am talking about in the link I posted earlier. I was deathly afraid of cutting the quarter pannel because 1) it has the orignal paint that I wanted to preserve and 2) I knew I wouldn't be able to get it lined up perfectly. By cutting the jams I had all the access I needed (it was tight) and when I finished I was able to patch it well enough for an amature that you can bearly tell. If you open the doors and look closely you can see I have been in there but with the doors closed you can't tell there was ever any rust repair and I only had to paint the longs and the door jam area.
KaptKaos
Oct 16 2007, 11:47 AM
Now THAT is a gumption trap!
zen motorcycle
Oct 16 2007, 09:04 PM
QUOTE(rhcb914 @ Oct 16 2007, 10:07 AM)
Thanks I jsut saw the harbor freight tool link the first time I went through. I like that way a lot better than cutting the quarter panel.
Time to go think about how I will
while I actually do this
