Just built this guy with stock web cam, rebuilt heads, blah blah. Thanks to Jakes video this thing doesn't leak a drop of oil
. After I first cranked it and set timing this thing hummed with no stumble. After a little driving this stumble began and now will not go away. I went and double checked the TBS and all is well there. It still looks new on the inside with little to no wear. This engine had 60k original miles when I rebuilt. The harness has been tested. I tore down and put back together the distributor w/ the Bosch grease. I am still using points/condenser. The trigger points looked ok and are definitely clean. Any thoughts outside replacing the trigger points? Could a stumble be caused by any other of the components? Again, the problem was not there at first. I am thinking I might yank the compufire off of my bug and throw it in there to see what happens...All thoughts are appreciated.
