QUOTE(ClayPerrine @ Nov 29 2007, 09:47 AM)
QUOTE(John @ Nov 28 2007, 09:22 PM)
As it typically goes with porn, it becomes addictive and others post porn as well. I don't think this should be any different.
Here is mine.
Where did you get yours done? Mine were from JetHot.
John,
How are these going to fit????
From the picture there is a bit of the tube sticking up above the flange. 911 engines don't have anything sticking up above the flange.
I really can't see how they will work.....
They do look great though!
I don't mean to hijack, but I wondered when someone would ask.
The extended tubes I added to the headers prior to coating serve the purpose of protecting the exhaust gaskets.
Mine go on 3.2 heads. The stock 3.2 exhausts have similar tubes extending into the heads to protect the gaskets as well (that is where I got the idea). It works well on the track car that way.
I also added extended tubes to the two extensions for the same reasons.
You may notice the tubes that fit into the heads are long. When I first fitted these to the engine, I noticed that they fit much too close to the cam housing than I would like so I made 3/4" thick spacers (not shown, but the exact size of the gaskets) to space the headers away from the heads and give me more clearance between the header pipe and the cam housing. Hard to explain, but I have no pictures of them installed here at work.
(Mine are also fitted to a Euro 3.2 which is why there is no O2 sensor bung installed.)
