914/6 conversion header porn |
rfuerst911sc |
Nov 28 2007, 07:01 PM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
I picked them up today from the ceramic coaters they look sweet (IMG:style_emoticons/default/biggrin.gif) If the pics worked my thanks go out to DR Evil who walked this computer idiot thru the process of resizing pics:beer1:
effutuo101 |
Nov 28 2007, 08:55 PM
Advanced Member Group: Members Posts: 2,734 Joined: 10-April 05 From: Lemon Grove Member No.: 3,914 Region Association: Southern California |
Nice Porn!
McMark |
Nov 28 2007, 09:20 PM
(IMG:style_emoticons/default/drooley.gif) That looks great!
John |
Nov 28 2007, 09:22 PM
As it typically goes with porn, it becomes addictive and others post porn as well. I don't think this should be any different.
Here is mine. Where did you get yours done? Mine were from JetHot. Attached thumbnail(s) |
rfuerst911sc |
Nov 29 2007, 04:50 AM
As it typically goes with porn, it becomes addictive and others post porn as well. I don't think this should be any different. Here is mine. Where did you get yours done? Mine were from JetHot. I am in Orlando FL. and there is a local coater about 15 minutes from my house. Nice looking headers you have there (IMG:style_emoticons/default/piratenanner.gif) |
Root_Werks |
Nov 29 2007, 08:20 AM
Village Idiot Group: Members Posts: 8,320 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Pretty! Nice headers guys, you both must be going for the torque factor on your engines. I am seeing both sets of headers with the three tubes meeting as late as possible. Perfect for something like a 3.0 or 911E cam engine.
Aaron Cox |
Nov 29 2007, 10:11 AM
cost?
rfuerst911sc |
Nov 29 2007, 10:14 AM
Pretty! Nice headers guys, you both must be going for the torque factor on your engines. I am seeing both sets of headers with the three tubes meeting as late as possible. Perfect for something like a 3.0 or 911E cam engine. Yes I'm useing a stock 1978 3.0 which does have fairly large heads but still makes good torque and horsepower. I'm leaving stock internals for now but will be running 40mm Webers. She should perform well at autocross,DE and just be a fun street car. I have a 83 SC also that is tricked out with major suspension upgrades and is a blast also. I really like these 3 litres (IMG:style_emoticons/default/biggrin.gif) |
ClayPerrine |
Nov 29 2007, 11:47 AM
As it typically goes with porn, it becomes addictive and others post porn as well. I don't think this should be any different. Here is mine. Where did you get yours done? Mine were from JetHot. John, How are these going to fit???? (IMG:style_emoticons/default/confused24.gif) From the picture there is a bit of the tube sticking up above the flange. 911 engines don't have anything sticking up above the flange. I really can't see how they will work..... (IMG:style_emoticons/default/confused24.gif) They do look great though! |
John |
Nov 29 2007, 12:12 PM
As it typically goes with porn, it becomes addictive and others post porn as well. I don't think this should be any different. Here is mine. Where did you get yours done? Mine were from JetHot. John, How are these going to fit???? (IMG:style_emoticons/default/confused24.gif) From the picture there is a bit of the tube sticking up above the flange. 911 engines don't have anything sticking up above the flange. I really can't see how they will work..... (IMG:style_emoticons/default/confused24.gif) They do look great though! I don't mean to hijack, but I wondered when someone would ask. The extended tubes I added to the headers prior to coating serve the purpose of protecting the exhaust gaskets. Mine go on 3.2 heads. The stock 3.2 exhausts have similar tubes extending into the heads to protect the gaskets as well (that is where I got the idea). It works well on the track car that way. I also added extended tubes to the two extensions for the same reasons. You may notice the tubes that fit into the heads are long. When I first fitted these to the engine, I noticed that they fit much too close to the cam housing than I would like so I made 3/4" thick spacers (not shown, but the exact size of the gaskets) to space the headers away from the heads and give me more clearance between the header pipe and the cam housing. Hard to explain, but I have no pictures of them installed here at work. (Mine are also fitted to a Euro 3.2 which is why there is no O2 sensor bung installed.) |
ClayPerrine |
Nov 29 2007, 02:44 PM
As it typically goes with porn, it becomes addictive and others post porn as well. I don't think this should be any different. Here is mine. Where did you get yours done? Mine were from JetHot. John, How are these going to fit???? (IMG:style_emoticons/default/confused24.gif) From the picture there is a bit of the tube sticking up above the flange. 911 engines don't have anything sticking up above the flange. I really can't see how they will work..... (IMG:style_emoticons/default/confused24.gif) They do look great though! I don't mean to hijack, but I wondered when someone would ask. The extended tubes I added to the headers prior to coating serve the purpose of protecting the exhaust gaskets. Mine go on 3.2 heads. The stock 3.2 exhausts have similar tubes extending into the heads to protect the gaskets as well (that is where I got the idea). It works well on the track car that way. I also added extended tubes to the two extensions for the same reasons. You may notice the tubes that fit into the heads are long. When I first fitted these to the engine, I noticed that they fit much too close to the cam housing than I would like so I made 3/4" thick spacers (not shown, but the exact size of the gaskets) to space the headers away from the heads and give me more clearance between the header pipe and the cam housing. Hard to explain, but I have no pictures of them installed here at work. (Mine are also fitted to a Euro 3.2 which is why there is no O2 sensor bung installed.) AHHHH.. I understand now..... :lightbulb: The tube actually fits into the exhaust port, thus making sure that the gasket seals properly. It would also help with alignment of the header. Cool Idea.. wish I had thought of it. I am going to use it on the new exhaust I make for my next motor. (IMG:style_emoticons/default/smilie_pokal.gif) |
jd74914 |
Nov 29 2007, 03:20 PM
AHHHH.. I understand now..... :lightbulb: The tube actually fits into the exhaust port, thus making sure that the gasket seals properly. It would also help with alignment of the header. Cool Idea.. wish I had thought of it. I am going to use it on the new exhaust I make for my next motor. (IMG:style_emoticons/default/smilie_pokal.gif) Thats how a lot of newer motorcycle exhausts are designed too. It makes them really really easy to put on. (IMG:style_emoticons/default/smile.gif) |
MoveQik |
Nov 29 2007, 03:50 PM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
John |
Nov 29 2007, 04:09 PM
I size the tubes to be a tight fit inside the header tube and a slip fit into the heads. (The 3.2 heads already have a recessed area machined into the exhaust ports to accept the tube). I then tack weld the tubes into the headers.
I square the ends on my lathe and then taper the inside of the ends that slip up into the heads for a smoother transition of the exhaust. I can't take credit. I stole the idea from the stock 3.2 exhaust I removed. I think the factory did it at most of the joints. I did it at all of my joints. They are easier to install and the gaskets don't blow out. .......... back to your regularly scheduled header porn ........ |
John |
Nov 29 2007, 04:11 PM
Nice tin. Where did you get that? |
MoveQik |
Nov 29 2007, 04:18 PM
Nice tin. Where did you get that? Thanks. I got it from a member/vendor here...I can't remember who! Joe O'Brien had his guy ceramic coat it. |
TravisNeff |
Nov 29 2007, 04:30 PM
You just know that Wills will be involved anytime there are shiny parts lying around. :bling:
John |
Lo-Fi Version | Time is now: 16th May 2024 - 12:48 PM |
