First choice, are you sure the stock FI is shot? It is the best system for a stock engine. Could you tell us L-jet or D-jet and engine size? Some guys here may be able to help you fix it.
2nd choice, I have the SDS programable FI group buy going on at the STF. We have 8 people so far, but you will have to wait till the end of April. IMHO way better than carb's and could be made to look almost stock.
http://shoptalkforums.com/bbs/NonCGI/Forum...TML/000668.html3rd choice, Mega Squirt as above but you have to build it yourself, DIY kit some assembly required.
4th choice, 44IDF Webers plus a Mallory dizzy, you will also need a low pressure fuel pump. Don't expect great results if your using a stock cam.
5th choice, buy a progresive carb and throw it straight into a lake, if it floats you can use it.
