Mark D said I could post this here, hope it doesn't piss anyone off :-)
This is a re-post from my forums...
WOW, after 6 weeks of effort, sometimes taking 20 solid hours per day in front of the computer I am all finished with the new program!!
We have revitalized every aspect of the kit program, for every kit and every application. The current program will remain in place and untouched through 2009 (except for inflation cost increases). The combinations, will remain a constant for the next 2 solid years.
The new program couples what we have learned in the engine shop in 2006-2007 into the kits making each of them better than days past in some way. As an example the new 2270 kits assemble without the need for cylinder shims, with very little case clearancing and now we can run more valve lift with a larger base ciircle cam. This makes the kit easier to build, stronger and reduces costs up to 150.00 per kit!
I'll go over some key aspects of the new program below:
How did we make the kits cheaper:?
It's simple.. Volume and common sense. We applied the changes and that coupled to the huge volume of kit sales last year helped us to drop the prices. QUALITY WAS NOT SACRIFICED TO DO THIS!!! The parts are the same and even BETTER than before, especially in the 2056 kits that no longer get stock rods.
What power changes were made?:
We now have kits ranging from 95HP (Camper Special) all the way to 210HP from a 2316.
Are the kits as easy to assemble?:
EASIER!!! Our kit combos swapped around a bit and we made changes for the better, making engine kits easier to build for most any novice.
Our biggest change in the program came with the addition of "Extensive prep service" meaning that with this option we will entirely mock up your complete engine kit. This means NO SPECIAL TOOLS, NO HEAD ACHES AND NO GUESSWORK!! JUST ASSEMBLE!!
We do the following for you:
-Clearance case
-Update galley plugs
-Check for radial clearance inside case
-Mock engine up
-Calculate deck height, compression ratio and measure chambers
-set valvetrain geometry and cut and assemble pushrods
-set flywheel end play
- Dynamic balancing and indexing of all components.
-Unlimited email support for the life of the kit
-unlimited support during kit assembly, via email and telephone.
-Much, much more..
All you need is a 100 piece craftsman tool set and a torque wrench!!! Literally!
The things that occur behind the scenes have also changed as I have streamlined the check processes and created a 137 point inspection that the kit will follow during it's evolution. This helps Blake and Rebecca do the work easily checking each other's work and frees me up for development and video production.
I have also added new forms and notes that will be included with each kit for more concise direction, until my support video is completed this summer.
Now, here is the real kicker... EVERYTHING is now in presentation format, meaning I have taken days and days of my time to create presentations covering the entire kit purchase as well as individual presentations for EACH SPECIFIC KIT! These go over everything from the specs of the kit, to what components are needed with the kit and even nclude the spreadsheets of information that go over the components included in each kit. Hell some of them even have testimonials and picytures as well! I even include comparative power ratings for each displacement!!
Now, with all this effort we REQUIRE our presentations to be viewed completely before we'll answer ANY kit questions! You will find that IF YOU READ AND PAY ATTENTION that most every question is answered..
So, without further delay please see the following link for the first presentation, the introduction to the kit program. You can view it as a slide showor as an outline.
Presentation Site
From this presentation you will click a link that will take you to the specific kit pages for each engine displacement. YOU MUST VIEW THE FIRST PRESENTATION BEFORE YOU WILL BE DIRECTED TO THE SPECIFIC PRESENTATION!!! Links to the main presentation are also available on each engine kit page from the type 4 Store.
Until the end of January we are offering the extensive prep service option for a reduced rate of 650.00, this is a priceless service that makes the kit so simple to assemble that it can literally be completed in one weekend without rushing!!
Wait no longer- order now!!
