Hi! I have a 1970 914 where i´m planning to put driving/foglights in the grills and the early 914 raise the headlamp when you pull the light switch to the first step, and what i´ve understand the later doesn´t.
So does anybody know how to fix so the pop-up´s raise just when you pull the switch to the second step (fully engaged). In this way so I can drive with just the additional lights on and no frog eyes.
As I said I also planning to put the extras in the front light grills and this car have newer had that, nor their is any pre-wiring for that on the early models. So I would appreciate if there should be som wiring suggestions on that as well.
I suppose there would be som faq on these issues but I haven´t found it.
Thanks!
Chriss
BTW. You can´t beat the fealing and sound of a 914 with a six in the middle!
