QUOTE(kaagkevers @ Jan 28 2008, 07:50 AM)
The engine is a 1.7 ltr stock with D jetronic.
I already replaced the temp. sensors and checked the feul pressure.
Checked and cleaned the injectors, controled the inlet pressure sensor and checked the ignition. Checked the inlet for leaking, checked the compresion and the valves.
What do you mean "controled the inlet pressure sensor"?
There are 4 things that control the fuel "mix".
1. the CHT-cylinder Head Temp sensor- test it using Brad Anders pages
2. Air temp sensor- it can effect the mix alittle
3. MPS-Manifold Pressure Sensor- The main fuel mix sensor, looks like a grenade mounted under the battery tray
4. Fuel pressure regulater- pressure should be set to 29lbs but you can adjust it upto 36 lbs tops..
