This thread's all over the place!
Too much has been made about pinch bolt struts. If you can find the later ones go for it. If not, check to make sure the hole is fine on the bottom (it probably is) and enjoy. Is this guy going 5-lug?
There's been a lot said about sway bars here... my personal preference is "through body" The under body bars are 18 (early 74-76) and 20mm (later). While the 18mm bar should be fine for the average street ride, I personally think 20 is pushing it. The stock 914 bar is 15mm and does a world of good if you are used to driving without it.
911 through body bars came in 12-13-15-16 and 18mm sizes. There are some more as well but, these are what you would commonly find on their street driven, through body, varients. 16mm was the most common through body bar.
One thing I didn't see mentioned here is the size variation in the drop links. The 914 drop links are roughly 3/4" longer.
As I see it, and how it pertains to the original poster, there are two options.
What's required:
Through body - A complete bar assembly, including; bar, end caps, arms, drop links and possibly u-tabs (depending upon what is included or not on the current a-arms). You'll need new bushings. You'll need an Engman body support piece. You'll someone to cut and weld on your body and you'll need to yank the tank to do it all. You should prime those areas and possibly re-apply the undercoating.
Under Body - You'll need the entire bar set up. You'll also need the rear brackets and possibly a crossbar from a later 911 (or some modifications to your own that would probably require pulling it). No welding and cutting but a fair amount of front suspension bits and pieces swapping. You'll need the A-Arms or you'll need to modify your by adding the later style mounts. The sway-bar mounts are different on the A-Arms. Personally, for a street car, I think keeping the 17mm t-bars is a good idea... soon you'll have 23mm t-bars and 26mm sway bars and the intent was to simply drive the car on the street.
Also... 914's don't need strut braces (yes, we're watching you Chappy)
The factory did a fine job of placing bulkheads in the proper places front and rear.
If'n I was the original poster here (and I ain't) I would do this:
1. Find a stock 914 bar set up (all the bits). Should be around $100-150
2. Call Mark Bland and get the body mounts.
3. Call Pelican and get all new bushings.
4. Call my friend with a welder.
5. Plan a weekend. Buy beer for the welder guy. Saturday AM, yank the tank, cut the holes and prep for welding. Weld. Paint. Undercoat. Install bar. Put the tank back in.
6. Sunday - Go for a drive.
Search is your friend...
