QUOTE(Vacca Rabite @ Feb 6 2008, 08:10 AM)
Use a siphon to drain the tank while it is in the car. If the gas is bad, dispose of it legally. if it is okay, put it in another car and use it.
Put fresh gas in the car, and you should be good to go. No tank pulling needed.
Now, if the gas is really bad, and has turned to varnish in the fuel lines, you will need to replace the lines and fuel filter, and that is easier to do with the tank out. But try the easy stuff first.
Zach
Zach thank you for your replies to both recent posts. In one of your threads, you purchased a mig welder. How did the one that you purchased work out for you? What were its capabilities.
