ne14914
Mar 19 2003, 10:40 PM
Ok guys - Anuder Dupid Kwestyawn
How do you check the transmission oil? I cant seem to find a dip stick ~
Brad Roberts
Mar 19 2003, 10:43 PM
No dumb questions... Feel free to ask anything you like.
Pull the fill plug on the side of the tranny and stick your finger in it. The fluid should just be at the bottom of the fill plug hole.
Note that the tranny has 2 plugs. One is higher than the other (fill plug) and the other is the drain plug.
B
ne14914
Mar 19 2003, 10:48 PM
Thanks Brad
This is my first 914 and Im trying to learn as much as I can.
Brad Roberts
Mar 19 2003, 10:55 PM
You came to the right place. Lots and lots of very knowledgeable people on this BBS.
Dont sit back and watch the board. Always ask your questions. I can almost promise a response 24/7 within 30 minutes of your post.
B
Dave_Darling
Mar 19 2003, 11:01 PM
Sears or your local VW Bug shop should have the 17mm Allen socket you use to remove the fill plug.
Some have used a combination of nuts and bolts as a socket, but several people have messed up their drain or fill plugs using those. The real thing is pretty cheap...
--DD
airsix
Mar 19 2003, 11:22 PM
QUOTE(Dave_Darling @ Mar 19 2003, 09:01 PM)
--DD
I walked into a FLAPS and said to the clerk "I need a 17mm allen wrench." He replied "We don't have any that big." So I said "Do you have a VW drain plug tool?" and he said "Sure, they're right here." And he handed me a 17mm allen wrench.
-Ben M.
Brad Roberts
Mar 19 2003, 11:33 PM
Normally its a cheap "chrome vanadium" 3/8 drive 17mm socket. I buy two at a time.
B
ChrisReale
Mar 19 2003, 11:43 PM
and if you decide to drain the fluid, remove the filler plug before you remove the drain plug. Learned that a few days ago.
Brad Roberts
Mar 19 2003, 11:50 PM
And... why do you remove the fill plug ??
B
ChrisReale
Mar 19 2003, 11:53 PM
so it acts like the carb on a bong! Try pouring a jug of water out into the sink. Observe the results. Then do the same, but cut a hole in the top. Much smooooother.
Mar 19 2003, 11:55 PM
QUOTE(Brad Roberts @ Mar 19 2003, 09:50 PM)
so it rinses out easier.
ever made a hole in a beer can at the bottom and then opened the top?
Andy
ChrisReale
Mar 19 2003, 11:57 PM
Never tried it, but Ive seen it done numerous times. Maybe Ill give it a try....
Brad Roberts
Mar 19 2003, 11:59 PM
Yes and yes...
newsflash... There is a BIG breather hole at the top of the tranny. If it is plugged.... your tranny will ooze fluid anywhere it can.
I knew why you pulled it.... smart asses...
B
Dave Cawdrey
Mar 20 2003, 12:14 AM
QUOTE(ChrisReale @ Mar 19 2003, 09:57 PM)
You never shot-gunned a beer? Man, do I feel old.
Atleast you recognize old school hip hop. Makes me feel young again
Mar 20 2003, 12:17 AM
QUOTE(Brad Roberts @ Mar 19 2003, 09:59 PM)
hehe, works every time
Curvie Roadlover
Mar 20 2003, 06:21 AM
The topic of why you open the fill plug came up about a week ago. I thought it was here, but maybe it was on the PP BBS. If you open the drain plug and fluid starts pouring out, then are unable to get the fill plug out, you will have a bitch of a time refilling and the car might be out of commission in the meantime. If you realize that the fill plug is stuck first, you can still drive the car (since you haven't lost your tranny fluid) until you resolve the stuck plug. I remember some people posted what a pain in the ass it was to try to fill the tranny from the breather hole. Just something to think about.
tahoward
Mar 20 2003, 07:14 AM
So glad to hear that happened to someone besides me...maybe I'm not cursed!!
JWest
Mar 20 2003, 08:46 AM
