QUOTE(bperry @ Feb 8 2008, 09:17 PM)
Depends on where you are getting your +12v from for you MS.
Where are you getting your +12v from?
There aren't that many sources for a switched fused 12v in the engine
compartment.
Hopefully, its not the same circuit as the coil.
If you have your own +12v switched circuit, then you can actually probably
remove 2 relays. The Fuel pump relay and the Power Supply Relay.
See this technical artical for locations of relays:
Fuel pump conversion for Carbs--- bill
The +12v is coming straight from the batt.
For the sw. +12v, I tapped into the sw. power from the main harness ( solid black wire). I T'd it where the stock harness enteres the engine bay.
Since all the FI stuff is now from the MS r/b, I did not have a need for the second wire harness that comes off the back of the stock 914 r/b and eliminated all but the starter, back up light wires and blower motor jumper from that plug.
Thank's for the link
Keith
