Full Version: Trans ratio
retrotech
Can some one tell me the difference between 4 cyl. ratios & 6 cyl. Basically are the gears raios closer on which one? Which has the lower ratio, ie lower max speed per gear.
Thanks
redshift
From memory...
/4: A, F, N, V, ZD
/6: A, GA, O, V, ZA.. I think..
The 6 has a GA mainshaft, 2,3 are higher, 5 is lower, obviously.
M
retrotech
So if you were running a 6, with 4 gear ratios, wouldn't that be good? Closer, lower, mid range gears with more torque, and a longer [higher rpm] 5th gear.
retrotech
Or did I get that just back wards?
redshift
Hey, found what I was looking for, and my memory works!
http://members.rennlist.com/chuxter/901&915ratios.htm
Changing either car, to the other's transaxle (stock) would not be a huge change.
If you have MS Excel, you can d/l the ratios.xls, and play with speeds_in_gears.
I deleted all the rpm cols. except for 3500-4500 and redline.
M
campbellcj
What's good for you, gearing wise, largely depends on 3 variables:
1) What you mostly use the car for, i.e. autox, tt/race, or street
2) What flavor of six you have, i.e. a high-revving small displacement or a 3.8 torque monster
3) Your tire height/circumference. Short tires have an effect of shortening gearing, and vice versa.
For my purposes (track) the stock -4 gearing was off. It was fine for street driving but did not allow good use of the powerband in canyon carving or track events.
I recall that John Rogers found exactly the same thing, but we have slightly different gears in our new gearboxen...
