Full Version: Thinking of adding a 912 to the fold
swood
I've got a family of 4 and it sure would be nice to take them all when the need to drive a P-car comes up. I figgered a 912 would be a (reasonably) economical way to go. I could put in a hot /4 and away we go.
I see theres about 7 or 8 of em for sale in the recycler pretty cheap. I know, you get what you pay for.
Elliot_Cannon
Hi,
Four people will fit in a 912 if two of them are less than 3 feet tall. I think 69 would be a good year. That year I believe has the same wheel base, chassis size etc. as the 911.
Cheers, Elliot
McMark
Yes, get a 69 if you can.
Britain Smith
I would recommend a '69. The parts are shared with the later 911's and you get the longer wheel base. Check out my site for more pictures of my '69 912.
-Britain
swood
Thanks. Yeah, so far my kids are little. I think it's a good change up from having two '14s. I'll check your site Britain.
This is actully the only one that says it's a '69. Don't like the whale tale though.
Recycler ad - I think
914ghost
Yeah, 912's rule. Lots fun of and you can fool the 911 guy's.
Not sure about economical, body parts probably not too bad, but regular engine stuff will be comperable in price to the Hi performance 914 stuff and a bit harder to find.
-Ever see a 356/912 with any parts at an average wrecking yard?
But if you do the work yourself and do it right, you'll always come out ahead on an old Porsche.
Unless you're me, but I usually do things wrong so I have something to do later.
Robert O
Tom Perso
Do a 69 with a T4 conversion. My friend Grant has one (a hotrod 2056) and it rocks.
IPB Image
IPB Image
He's got 16x6/7 (front/rear) on it and it looks the part of a 911.
Other than the liscense plate that says...
"NOTA911"
LOL
Tom
Britain Smith
I recently sold my awesome 912 engine after I made the commitment to the type-4 power. But I think I am taking the concept a bit further...I am build a 2.3L type-4 engine, turbo-charged, Tec-3 FI, 98mm nickie's, with a 911 fan shroud. It will look like a 911 engine when you open the lid, but only have four cylinders...and go like hell!
-Britain
seanery
912s are cool. There are decent bargains on good ones at Pamona. I've seen solid, clean cars go for 5k or less.
Stay away from 912E's unless you want a truly bastard car. There are lots of 1 year only parts on that car.
swood
Cool info guys. I think that would be a nice thing to have. I really like the T4. I'm just not interested, at this point, to get into /6's. A bit rich for my blood.
Zeke
Steve, understand that the early 912's to '69 share nothing in common with the TypeIV that you have worknig knowledge of. When you said "hot rod 4," you can't mean the early motor. That would cost you as much as a 6. The '76 912E is the one with the TypeIV, but try to find sheet metal to put a TypeIV in an early car. Since they made the car for one year only, the SM and other parts are very rare and expensive. Either get a '76 (they're not cheap) or plan on putting a TypeI in the earlier 912 (dog) or plan on spending as much as you would doing anything else. There ain't no free lunch.
McMark
The 912 (and early 911s) has a 901 transmission just like the 914, which means that a Type IV bolts right up into a 912. The stock cooling even fits. Gotta modify tin and make a mount bar, but as far as putting a Type IV into a 912 it's a cakewalk. EASY!
bmendel
something to think about with a type IV in a 912, even though the engine will bolt right up to a 912 transmission, the gearing will be all wrong for the type IV. You really need a 914 gearset in there, but you can't just use a 914 transmission or you'll get 5 reverse gears and one forward...
Tom Perso
Agreed on the gearing - it's not too bad, but my friend is replacing his trans with a modifed 914 unit (flipped ring gear) and it should be all good.
Cooling tin is cake and exhaust is as well. Get a set of 411 heater boxes (then you have heat), a bus header (or BAS system), some U-bend, and a muffler.
IPB Image
IPB Image
Later
Tom
swood
Very interesting info guys. I'd like to look into this more. I've heard of a few guys (I think) flipping something in the 901 to use it in this type of application, just cant recall.
What are the general differences, good and bad between the early 912's and the '76? The '76 had a 2.0 with L-Jet? That doesnt seem like a bad platform to start with. I've seen two of them over the weekend in decent shape for about 7500.00.
Joe Bob
Type IV 914 motor n a tail dragger.....can't be done.....
redshift
Steebo,
Get a 912E if you like, but get a roller, and buy a used TIV out of a 74 914, if you want injection.
M
Joe Bob
912 E.....best bet. They get no respect, I had one for sale....club owner that died....beautiful original car....sold for like 4500.00......
They should start increasing i9n value once smog exempt and you can get rid of theose thermal destroyers.
rhodyguy
4500 for a nice E would be a smoking deal up here. they seem to command a high premium. they are galvanized, correct?
kevin
swood
If the E's have a T4, what trans do they use? a 901? and is it in front of the engine?
Are there any online manuals available like we have here for the 14? I need to do some more research.
M-
I've got the '74 914 donor in my garage if I need another t4 and trans
McMark
There seems to be a lot of misinformation going on about putting a TYpe IV in a 912. I put a 914 engine in my girlfriends '69 912 and she drives it to work every day. I don't know if the gearing in a stock 912 901 transmission is optimal, but it definatly works really well with the inches-from-death, worn-out, 50-psi-per-cylinder-compresion motor that's in there. I'll be able to tell if the gearing sucks after the 2056 goes in in a couple of months.
To be clear: the 912s came with a 901 stock. You do not use a 914 tranny in the car. You will not have 5 reverse gears. You do not have to do anything to the tranny.
All you do to put a Type IV in a 912 is:
Step 1: Remove stock engine.
Step 2: Install stock 914 engine.
DONE!
Dave_Darling
The 912E used a special version of the 915 gearbox that had a 901 input shaft. I believe it also had unique engine tin. It might have been as simple as Bus tin with 2.0 914 spark plug holes, but it may have been more specialized.
912E-specific parts are rare and $$ in general, since they only made 2099 of them. Some FI parts, exhaust, transmission, engine tin, tranny mounts, etc.
I don't like the E, frankly. The mid-year 911s were galvanized (yay!) but I feel are too heavy. The early 911 chassis can really scoot with with the 90 HP 912 engine under it, while the stock 912E feels much less zippy.
I prefer the SWB (63-68) 911s and 912s; I think the "stance" is better than the later ones. But that is just a "looks" thing. I would be surprised if the rearward weight bias of the 69 911 were better than that of the 68 912--the four-cylinder engine is significantly lighter than the six.
An SWB 912 with a warmed-over 2.2 Type IV would be a very niftly little car! smile.gif An upright cooling conversion would help keep the weight lower, and would move the CG forward a bit which is also nice.
--DD
swood
First of all, that damn burger turns my stomach. I had a Tommy burger with chili yesterday, and that's all I can taste. Every time I burb I want to puke. Purge...purge...purge...I digress...
Since I'm speaking out of ignorance, youre saying that both the early and late model 912's use a different tranny than the 914? and that they are sufficient for a stock 914, but you're not sure about a bigger T4?
McMark
63-69 912s came with an identical version of the 914 tranny in the bellhousing and inputshaft area. The 76 912E came with a modified, one-year only 915 tranny.
All 912s will take a Type IV engine without any tranny modifications. The tranny internals (gears) are nearly identical to the 914 engine (I'm not sure the ratios are the same) so the tranny is good for 150-200 hp, just like a 914 tranny. You can put a BIG 4 in a 912.
914ghost
Since the 914 901 tranny is backwards, doesnt that mean the ring gear is on the other side of the pinion?
I know the engines rotate the same direction and the tranny housing is pretty similar (if not the same).
I don't know if flipping the ring gear around is possible.
Also, what does 'gearing' as far as the tranny goes have to do with the actual engine? The idea is the wheel turns once for a certain number of turns of the input shaft, each gear having a different "ratio" of wheel to input shaft turns. Eh? blink.gif
I drove an experimental 912 w/ an electric engine once. Strange, quiet, gutless, but it drove.
The only real solution is a 912 w/ a 914 tranny and a corvair engine adapted to it. lol2.gif
Robert O
Tom Perso
Let me stand corrected. 912's did come with 901s, which a 914 T4 WILL bolt up to, just some tin adjustment needs to be made.
My friends car has the odd-ball 4-speed transmission so thats why a 914 901 box (with the flipped R/P) is going into it.
The 912E had a 923 transmission, it's a hybrid 915 with the 901 style inut shaft (so it works with the T4 Porsche 914 style flywheel.
There.
Tom
McMark
I'll specify further:
If you have a 912 with a 5 speed transmission in it, leave the transmission in place and bolt the Type IV to it. DONE.
The transmission doesn't change!
If you have the 4 speed version then there might be more of a problem. I'll research that, but I'm pretty sure it's the same story.
Gumby912
Converting an early 912 to type 4 power is as easy as has been said. But you need to determine if that's why you are buying the car to begin with. Early 912's and even 912E's are starting to increase in value. Converting an early one to type 4 value may hurt it's future value. I purchased my 67 912 without and engine and did a type 4 conversion. If you are planning on using a 2.0 914 engine, the 912E sheetmetal will fit perfectly. You will only need to create an engine support mount, carb linkage, re-gear the trans, and fabricate an exhaust. I am using VW 411/412 heat exchangers just like the ones shown earlier in this thread (not as pretty as those!). I modified a 912E Bursch exhaust to fit these. I salvaged the gear set from an early 914 tail shifter and rebuilt my transmission with them. Pretty simple job and made a world of difference. Otherwise, you will have the wrong gears to match your type 4's torque curve and will run hot on the freeway at 80-90 mph. Not to mention lousy gas mileage. Once I regeared, I now pull around 36 mpg on the freeway running 80-90 mph with plenty of power.
On prices, if you choose to get an early 912 and want to keep the stock motor, parts are getting harder to find. Average rebuild cost is ~$5k for stock. I know someone who just had a "hot-rod" 912 engine built for $7k and it is about 115-125hp range. $7k on a type 4 will get you alot more hp than that!
912E's have always gotten a bad rap. They are basically a 76 911 S with the 914's 2.0 Type 4, and the 1.8's "L-Jet" fi. I have a friend who owns a 76 912E with well over 200,000 miles on the stock motor. I helped him do a tuneup a few weeks ago and we did a compression check. All 4 cyls were between 150-155 psi!! No, they are not hotrods but when the suspension is setup properly, they can give 911's and 914's a serious run in the autocrosses.
--Tony
67 912 2.0 Type 4 "Gumby"
72 914 1.7
Zeke
Well, so far, only Dave D and myself have acknowledged the rarity of sheet metal for a T-IV into an early 912. Someone else says 'cake.'
At least it's something to look in to.
No one has mentioned the sideshift vs. tailshift with respect to using the 901 out of a 914. I'm sure it can be done, but with the tailshift. The 911/912 is a 'tailshift' turned around.
I don't know about gear flipping, but I remember reading of transplant motors that turned the other way. To compensate, they flipped the ring gear.
Obviously, a complete car is the way to go. But, Woods is looking at utilizing his resources to put together a family car, not spend a fortune, me thinks.
912 rollers are going cheap as of yet around here.
swood
Hey Zeke. I'm just stirring it up to see if the issue becomes clearer. I've never driven one, but think they're pretty cool. I just can't deal with the cost of a /6. But maybe the answer is to wait until I can. And get one that has the "legendary" (sic) longevity. The '76's are cool with a 2.0 in em. But I wonder about that single year tranny. But I'd take a early '12 if I could later upgrade to a bigger /4. I know the early stock motors have the suckage factor.
I'm glad though to read what everyone posted. Good food for thought. Thanks.
Eric_Shea
Anybody got any pictures of those elusive 63, 64 or 65 911's and 912's? blink.gif
Are we counting Paris 901 prototypes as model years now?
McMark
Yes, the tin is one of the 3 or 4 issues that must be dealt with to put a Type IV into a 912.
Zeke, why do you insist on putting a 914 transmission into a 912? It's not necessary!
Britain Smith
I actually have a set of that "rare" 912E sheetmetal. I might not need it and might want to sell it. It was actually quite difficult to find a complete set...I had to find misc. pieces here and there.
-Britain
ArtechnikA
QUOTE(rhodyguy @ Jan 19 2004, 08:04 AM)
i see a lot of sellers try to price them like they're gold "rare - only produced one year..." there's a REASON they were only produced one year !
they were I-series cars and used the Thyssen steel.
they used a type of 915 transmission with a modified bellhousing.
ArtechnikA
QUOTE(Eric_Shea @ Jan 19 2004, 07:57 PM)
i had a '65 912. Euro model. they had them there a year before they arrived here in North America.
i have pictures, but all they show is yet another rusty early 900 car with dead paint.
maf914
Tom,
Thanks for posting the photos of G's car. I followed his project when he was posting on the Type4rum last year.
I'm curious about his engine/fan shroud and exhaust system finish. As I recall, he polished, painted and clear coated the engine/shroud and Por 20 coated the exhaust. How are these finishes holding up?
Mike
Eric_Shea
I had a 911 "made in 65" but here they called it a 66. I was just thinking that if this chap is out there "Thinking of adding a 912 to the fold" then we might want to help him out by keeping it relevant to model years they actually built the cars. But hey... good point Rich; there might be 2 or 3, 65 Euro 912's floating around out there. cool_shades.gif
BTW... PM me if you're seriously looking to buy a 912. I know of a one family car that is for sale in NM. I will be going there in a couple of weeks for a PCA Zone meeting and I can do a pre-purchase inspection. It is currently not advertised.
Tom Perso
QUOTE(maf914 @ Jan 20 2004, 06:10 AM)
Tom,
Mike
The finish is holding up OK, but the mag. fan shroud gives up it's shine pretty quick. Wasn't really worth the effort.
Ok, for tin...
Use 914 tin. At the rear of the engine, you use the 912 motor tin with a little adjustment. This setup allows the 356 motor to be put right back into the car without any changing over. This WILL NOT devalue the car in any way (as long as you keep the 356 motor).
This was an easy conversion and I'd recommend it to ANYONE with 912 (non-E).
Later
Tom
