Hi Jesiv,
I just did the valve adjustment on my 1.8 a week ago, so I've got a good memory for the frustrations involved. They are:
1. Porsche didn't include a TDC mark on the fan. As you pointed out, the only mark is the 7.5' ATDC mark for cylinders 1 and 3.
2. It's impossible to see the factory timing mark unless you use a mirror. The Porsche engineer in charge of the fan housing design included a v-notch on the front of the housing that matches the v-notch on the back of the housing. Unfortunately, he didn't tell the engineer in charge of the timing marks and as a result, there is no timing mark in the front of the fan to be seen in the front v-notch. To see the factory mark, you'll need a mirror. I've added a mark with a white paint pen on the front of the fan that is visible in the front notch.
3. There's no good way to turn the engine over. I took out the plugs to reduce compression and was JUST able to turn over the engine with my left hand on the alternator pulley. Note that I was turning the engine backwards.
4. The mark on the fan is only used for cylinders 1 & 3. You'll have to guess about the location for cylinders 2 & 4. Fortunately, accuracy isn't crucial for this operation.
Here's how I did the job:
1. Remove the plugs. Remove the distributor so that you can see the rotor.
2. Pull off the valve covers. Before doing so, lay some rags, paper towels, or other absorbent material on your heat exchangers to collect the oil that will drain out of the heads. Otherwise, you'll pump oil smoke into the cabin for the next 2 weeks and your wife will refuse to ride in your stinky car.
3. Turn over the engine until the timing mark is aligned in the notch and the distributor rotor is pointed at the location for the #1 plug wire.
4. Get under the car and verify that BOTH of the valve rockers on the #1 cylinder have clearance to the valve stem. If only 1 valve has clearance, you should double-check that you've actually got the crankshaft positioned properly.
5. Set intake and exhaust valve clearances on cylinder #1. The inner valves are the intakes. The outer valves are the exhausts. You'll note that you have no room for a screwdriver on the #1 intake valve. Good luck on that one. (Hint: this is the only use for that silly bent screwdriver thingy out of the Craftsman 19-piece screwdriver set.)
6. Rotate the crankshaft backward 1/2 revolution until the distributor rotor is approximately 90' from the #1 position.
7. Get under the car and set the clearances for cylinder #2.
8. Repeat for cylinders #3 and #4, sequentially.
9. Reinstall the valve covers, distributor cap, and spark plugs.
10. Start the car and marvel at the spreading pool of oil under the passenger side of the car.
11. Remove the passenger valve cover and reseat the cork gasket.
12. Drink a beer. You deserve it. In fact, drink four beers, one for each cylinder.
QUOTE(Gint @ Apr 6 2008, 07:45 PM)
Get a mirror and look at the back side of the fan through the inspection hole. There is a cutout there also at the top of the housing. There should be a TDC mark on the back side of the fan. At least there is on my 1.8 fan.
BTW, the 7.5(?) degree mark (7.5 degrees of crank rotation before (after?) top dead center) on the 1.8 fan is close enough to TDC for the purpose of doing a valve adjustment. Just make sure the valves are closed and go.
