Yeah, so, here's a good one:
After it was split and the components removed, I took the two halves of the crankcase (75 2.0) in to have them boiled clean. They looked real nice after I got them back and I was oober excited about finally getting the engine put back together. So this morning I'm taking care of some of the little BS work, when it occurs to me that I never inspected the oil pressure relief valve. So I flip the motor on my engine stand, remove the plug and spring, shine my work light down into the bore and... It hits me like my ex-wife used to... idiot, you never removed the valve before taking it in to be boiled!
So now, the valve is stuck- I mean REALLY stuck- in the bore. I've tried using a hammer and punch to tap it loose but to no avail. I tried using my torch to transfer heat through the casting, but since I've already attached the oil filter flange, the flame wants to smolder the gasket down to nothing. So now I'm at a loss as to what might work to get it out of there. My book says to lightly screw a 3/8" tap into the hollow of the valve and pull it loose, but I'm assuming that's only when you haven't let it get boiled and I don't want to risk damaging it or the walls of the bore.
Any suggestions? Thanks.
-Brian
