Finally got some time to work on my car. I installed a gauge cluster from a 2000 Subaru Forester, and moved the shifter to a better location (my original placement was too low and far forward). I also changed the geometry of the fore/aft movement of shifter.
I decided to go with a more modern Subaru gauge cluster instead of adapting an electronic Porsche 911 speedometer and/or aftermarket gauges. The Legacy dash is too wide to easily fit in a 914 dash structure, so I searched for a Forester or Impreza cluster instead. I found one from a guy parting a 2000 Forester; bought it for $50 with plugs and a few inches of wiring for each of the three plugs on the back of the cluster. I also grabbed the dash surround, since I'll need to build a new dash top because the Forester cluster is taller than the 914 3-gauge cluster. I also bought a factory service manual including wiring diagrams on Ebay for $8.00. After figuring out the wiring, I dove in...
I had to remove the front "hoop" of the dash structure, and weld in three new mounts. I spot-welded two mounts on the backside of the 914 dash structure for the two lower Forester cluster mounts; I welded in two 6mm studs for those two mounts. For the single upper mount, I welded in a piece of bent-up 18gauge strap steel with a hole drilled in it to match the Forester cluster's upper mount.
I wanted to keep the cluster as low as possible so that my Momo steering wheel wouldn't obstruct the gauges. Everything works, with the exception of the fuel gauge and low-fuel lamp -- I'll need to figure which resistor is needed to synch 'em up. It also turns out the Forester I pulled this from had almost 230k miles; I will do some research to see if that can be reset to zero.
In total, I spent a couple hours figuring out the wiring, and probably three hours on building & welding the mounts. I musta had it in/out a dozen times. Below are some pictures.
The first pic shows where the factory 914 hoop was mounted (see the two shiny spots), as well as the upper mount in welded in. You can also see the spotweld burn marks on the front of the dash for the lower mounts on the back of the dash structure.
Click to view attachmentNext is the back of the dash, showing the two lower standoff mounts. They're angled, so they took a lot of massaging to get just right and avoid blocking the stock 914 switch mounting areas.
Click to view attachmentBelow shows the back of the dash with the cluster mounted; this picture gives a better perspective of the two lower mounts.
Click to view attachmentNext is view of the cluster through the steering wheel; I'm also holding up the cluster surround that will help me design the final dash top out of fiberglass. Never mind the state of the cluster face -- I used tape to protect the clear plastic face from scratches during the trial fitting, re-fitting, re-fitting, etc.
Click to view attachmentOne more pic from an overhead angle. I like it!
Click to view attachmentI also was able to change the mounting of my cable shifter, as well as fix the geometry. The former was a simple matter of drilling new holes in the 914 center tunnel and using standoffs to raise my shifter "console" shown in post #115. I didn't take any pictures of the shifter console as mounted, but the shifter is now aligned on a plane with the steering wheel.
I also didn't like the very short throw between 1-2 and 3-4 on my MR2 shifter. The only way to change it is to alter the fulcrum, since the push-pull action of the shifter mechanism on the back of the Suby transaxle is essentially non-adjustable. So I cut off the factory cable attachment point from the MR2 shifter lever, fabricated a new one, and welded it on about 0.5" lower. It is much better now; below are before/after pics of the cable mount.
Click to view attachmentClick to view attachment
