So I'm trying to remove the CV axles on my '75 so I can tear them down and inspect/clean/repair (if necessary) them. The haynes manual tells me that I should be able to loosen the 4 bolts holding the clamping ring in place, slide the boot back, and remove a snap ring that's holding the axle into the hub.
Okay... problem is, one of the bolts is rounded out. I couldn't really get a good look to be certain, but what's worked for the others is a 6mm allen wrench. I got them all loose on one side, even went so far as to take them out, but I'm not getting any movement on the boot what-so-ever.
But I'm also curious if those bolts are actually allen head as opposed to maybe a torx head? And if this one is rounded out like I suspect, and this is how the CV axle is supposed to be removed, then does anyone have any suggestions on what I might do to remove it? There's not enough room to get a pair of vise grips on it. The only solution I can think of is doubtfully the best way to go- that being that I have a set of easy outs, which would mean drilling through the bolt some and then using one to remove it.
Any suggestions are appreciated. Thanks. You guys
