I'm researching what it would take to convert my '74/4 rear axles to 911 parts as a potential approach to my rear 5-lug conversion. The piece of the puzzle that's got me confused right now is the joint flange, the piece which the transmission-side CV joints bolt up to. PET shows two part numbers for the '70 911:
- 901 332 209 15 - "for chilled casting"
- 901 332 209 21 - "for die casting"
- 914 332 209 01
1. Despite different part #s, my understanding is that at least one of the 1970 911 joint flanges *will* fit my 914...correct?
2. Which of the two 901 part numbers should I be on the lookout for, and what's the difference between the two?
Shout-out to Eric Shea for schooling me on this stuff! (Eric, I figured I'd go ahead and research in case our parts swap doesn't pan out for some reason. Can't hurt to learn a little more... ).
Thanks,
Reid
