QUOTE(SirAndy @ May 2 2008, 04:05 PM)
HOW TO: run the fuel pump for carb conversions, the easy solution!
http://www.914world.com/bbs2/index.php?showtopic=25954 Andy
I think the original question was related to how this really works or
is supposed to work.
The mod in the Tech Article is very simple and runs the pump when ever the key is on,
regardless if whether the engine is actually running.
The factory circuit in the FI system monitored the distributor ignition to tell if the
engining was running. To long without sparks, and it shut down the fuel pump
as a safety feature.
In order to perform that function you need a circuit that monitors something
like oil pressure or the distributor.
It wouldn't be that hard to add in one of the off the shelf
fuel pump cutoff switches that uses oil pressure.
Or for a few bucks in parts for resistors, caps and a transistor, you
could monitor the distributor where it feeds the low side of the coil/tach
which would mimmick the factory behavior.
A quick and easy safety measure is to add an inertia switch that connects
the ground to the T4b connector. This way in the event of a collision, the
switch throws, disconnects the ground, and shuts down the fuel pump.
This seems to be coming up every now and then. Perhaps I should update
the Tech Article to explain this better and include some safety fuel pump cutoff
options????
--- bill
