jfort
May 11 2008, 07:14 PM
The day finally arrived - flare project done. Picked up car Saturday. Drove the 5 mile trip home. It was running rough but it has been all winter with little running. I put in new spark plugs. Still idled rough. I would hear a crack sound while I was watching it idle. Noticed arcing from side terminal on coil to center terminal. Tried to move the car and the engine quit and it will not re-start. Bad coil? I have a new one on the way. What else could it be?
Rusty
May 11 2008, 07:19 PM
I'd check your plug wires. If they are not conducting properly - the spark will want to jump to somewhere.
I would consider cleaning your plugs, too. They are likely fouled if the spark isn't strong enough to burn all the fuel in the cylinder.
proto31
May 12 2008, 10:15 AM
You might have fried your CDI box with all that shorting going on, that would be a good explanation as to why your car will not starts. Hope you have a spare!
6freak
May 12 2008, 10:23 AM
QUOTE(Rusty @ May 11 2008, 06:19 PM)
Try the coil first borrow one or something !just get it running !shut the garage door and turn out the lights!(easy at nite) if the spark is jumping you will see it .if you still think its a plug wire GRAB it with you bare hands if its bad it will shock the hell outa ya ..at least yell know if its your wires` Come on dont be a pussy just grab it .....And yes it will hurt
IronHillRestorations
May 12 2008, 01:30 PM
The CDI box will make a faint whine when it's on. The CDI ignition does not use a coil, it looks like one, but it isn't a coil.
jfort
May 12 2008, 02:01 PM
thanks for the responses. i can't believe it is a spark wire. they are relatively new -- the orange, expensive one. but we will check. my mechanic friend is coming out for a house call on Wed. He knows (and tried to explain to me) that it is something different from the classic coil for the CDI that I have. He has ordered a new one. I hope it is not the CDI box itself. I am hoping he has a spare so we can isolate the problem. I remember replacing one on a 911 one time and it was expensive.
SLITS
May 12 2008, 04:22 PM
Factory calls it a "transformer". Instead of being fed about 9 VDC (conventional coil with resistor), the CDI shoots about 3 - 400 Volts at it.
6freak
May 13 2008, 09:42 AM
QUOTE(SLITS @ May 12 2008, 03:22 PM)
problem solved yet????
jfort
May 13 2008, 01:38 PM
can't work on it 'till tomorrow - Wed. My friend/mechanic is bringing CDI box, the coil/transformer and some plug wires. Hopefully we'll isolate issue. I'll let you know what happens. I sure appreciate your thoughts and input. I NEED TO GET THE CAR RUNNING.
jfort
May 20 2008, 08:49 AM
update - My mechanic brought a new Bosch transformer/coil and installed it. Still no spark. Then he noticed that the CDI box was loose. He tightened it. Car runs fine now. Must have been bad ground due to loose bolt. However, now my tach doesn't work. The arching and sparking I noticed earlier was right where the take-off is to the tach. I checked the connections at both ends. OK. The tach is grounded and getting 12v. I think it must have been damaged by the coil/CDI box issue.
6freak
May 20 2008, 09:45 AM
QUOTE(jfort @ May 20 2008, 07:49 AM)
If its not one thing its two .bummer ...i dont have any extra tach`s sorry..good luck
Rusty
May 20 2008, 09:52 AM
if the car is a factory six, there is a ballast on the relay board that you can check. It's a small silver cylinder. About 1" in diameter, 2.5" high.
