Woo Hoo!!!
Set the timing last night. Drove the car into work this morning!! Took the long way.
Car was ALMOST perfect.
Head temps never exceeded 300 even under load (never went to WOT or over 4k rpm). But mostly stayed around 250-275.
Only two issues so far.
1) Idle turned to cr*p when the car fully warmed up. Pretty sure it's a mixture issue. Need that wideband ASAP. No problem for the shakedown drive, just made sure to keep the revs up when stopped.
2) Oil temps got a little too high. 220-230. Ambient temps were 75+, 45 minute drive, shakedown drive varying rpm, varying load. I might have the timing too far advanced by a couple degrees, so will back it off as soon as I can. Wondering if it's just that it's a tight motor, running break-in oil.
Anyway, it's not gonna stop me from driving the car to the 914 lunch today. Fortunately, it's just down the road from work, so it's an easy drive. The drive home might not be the long way though, ambient temps are gonna be a lot higher, so I might just take the more direct route home.
-Josh2
