QUOTE(Justinp71 @ Jun 2 2008, 09:28 PM)
Holy Cow Andy!!!
> Did you convert your car from a 4-cylinder? - YES
> Do you need the single belt pulley? - NO, but the stock pulley would just be dead weight as i don't run anything off it besides the alternator
> Can you run a 3.6 with 1 5/8" headers? - YES, but you might lose some higher rpm power
i never said my list is a MUST for a 3.6L engine. you sure can use different parts, less quality parts, smaller parts, cheaper parts, used parts or anything else you can come up with.
i simply listed what *i* used for my conversion. the price was actually closer to $20k as i did some additional work "while i was in there" that was not directly related to the bigger motor.
but if you're converting from a /4 car, you may also want to consider bigger/better brakes and updated suspension, which will set you back another few grand ...
and then you might be inclined to make it look nice too.
and stiffen the chassis a bit. maybe a long kit or even a rollcage.
and then ...
Andy
