QUOTE(Lavanaut @ Jun 11 2008, 10:52 AM)
Does a thread like this already exist? I did check in the "Originality and History" forum, but didn't find it there.
Thanks
After a good amount of info from all sorts of people added to this thread, I went back and skimmed what I could wrap my head around. Here's what I've come up with (slowly adding links to pics as I have time):
Cowl-to-Fender Seam:
absent (metal-filled) or
empty for very early 70 (up to #49),
rubber seam thereafter.
Ignition Switch:
on dash, left of column for 70 & 71, on right side of column for 72
Interior Mirror: small version for 70, larger for 71 & 72
Dash Top: wide opening for glovebox for 70 & 71, narrower for 72 (to accommodate dash vents)
Dash Vents:
Absent for 70 & 71, present for 72
Door Panels:
smooth vinyl for 70 & 71, basketweave for 72
Glove Box: wide for 70 & 71, narrow for 72 (to accommodate dash vents)
Main Wire Harness: /4 harness for 72 cars
Passenger Seat:
fixed for 70 & 71, moveable for 72
Rear Bumper:
squared off for 70 and early 71,
rounded for later 71 and 72
Seat Inserts:
smooth vinyl for 71, basketweave for 70 & 72
Seatbelts: non-retractable for 70 & 71, retractable for 72
Steering Column: /4 steering column for 72 cars
If you know of further differences, please post to this thread and I'll include them in this list. And thanks to everyone who's contributed!
Reid
Reid,
I totally missed your ensemble of differences you've now listed on the front end of this thread since it got moved here from the garage. Not sure if anybody else saw this or not. A few items I'd like to address;
I have two '71 parts cars. Both have the small mirrors.
The early seat belts were installed in most '72's until about June of that year. See Mel Rekling's '72 six interior pictures.
The broad statement of the main wiring harness being the same as the /4 needs a lot of clarification. I would say that it could be the same as a ROW /4 from the dash forward, but from the dash back to the engine is quite different because of the engines. Again, as has been stated before, the '72 /6 is a ROW car and wasn't officially imported.
And......don't forget the foot rest in the '70 & '71 cars. The carpets are also different in a '72 with a foam block on the front bulkhead replacing the foot rest.
Really, the bottom line here is that the basic body and trim is a /4, the basic mechanicals are /6. (Even then I don't like that broad statement) The '72 six is unique to itself and very rare in this country.
Anyway, keep working on this thread. I'm sure more can be added from others.
Don
