I'm in the process of installing AA's upper fuel line kit, but I'm not certain how the long FI fuel line goes across the engine from one side to the other.
Here's how I've placed it, is this the correct location?
Also, I need some assistance with the wires....
I have a red wire coming from the Aux Air Valve, where does it connect to?
I also have a white wire from the wiring loom, does it connect to the white wire at the quick connect, next to the distributor?
Also, where does the black wire from the distributor connect to?
Finally, do I have the distributor wired correctly and should the spark plug wires go beneath the intake manifolds?
-- Rob
