http://www.pegasusautoracing.com/group.asp...=CALIPEROUT4000
Outlaw 4000 Series Brake Calipers
Outlaw Calipers are made from billet aluminum for strength with stainless steel pistons for thermal insulation. Differential piston bore sizes help to minimize pad taper wear.
4000 Caliper Series specifications:
Housing Material: Billet Aluminum
Mounting Centers: 3.50"
Inlet Threads: 1/8 NPT
No. Pistons: Four
Piston Material: Stainless steel
Disc Thickness: .38" - .81" - 1.25"
Disc Diameter: 11.75" - 13.00"
Pad Type: PFC751, HB101
Pad Area: 7.21 sq/inch.
Pad Thickness: .80" (20,3 mm)
Heat Shields: Stainless steel
Weight: 3.9 lbs
No. Pistons: Four
Weight: 3.9 lbs
Andy
