It took awhile longer than expected to get everything back from the manufacturers, but they're finally ready to ship out.
If you missed out on the pre-order special, I've decided to extend the $50 discount until the end of next week. These are ready to ship out right now and will only cost $450 if you order a set before 08/08/08!
FreeMotion rears will become available next month. I've redesigned the system and the new design will be much easier to install than the previous iteration. The new ones use the existing tailing arm pivot shaft, which saves quite a bit in manufacturing costs. So the rears will be available at a comfortable $250!
PMB Performance is a reseller for all of these components, so you can add these components to any trailing arm rebuild or caliper rebuild order. Imagine a powdercoated trailing arm, ready to bolt on with a vented rotor, new calipers, FreeMotion bearings, and new wheel bearings.
I also searched up a couple of old threads:
Leo Imperial Installation Thread
Owner Endorsement Thread
