QUOTE(turnaround89 @ Aug 25 2008, 06:19 PM)
The old fuel pump has three inlets/outlets. I was told i could use a new aftermarket fuel pump, however the new fuel pump has and in and an out, how can i hook up the new fuel pump so that it will work with the fuel system? The engine is a 1.8L carbed. Do i have to hook up the return lines back to the fuel tank? thanks everybody.
just a thought:
why not use the o.e. fuel pump and open the o.e. fuel regulator to 3 or 4lbs (or whatever you'r running). i've never tried opening adjustment to lower fuel pressure to that point... anyone know if this is possible? the return lines benifit you by circulating the fuel, helping it keep cool.
by the way your o.e. pump has 3 fittings
1 inlet from tank
1 outlet to motor
1 outlet (tees into return line to tank)
(i believe) 75 up are have only 2 nipples
if you use an after market pump just plug the 3rd (from o.e. pump) line that tees into return hose to tank
