'74 V8 914 For Sale.
Engine:
355 cubic inch Chevrolet 4 bolt main.
350+HP/350+ft. lbs. torque.
Cooling by high volume Meziere remote electric water pump to a Griffin 3" aluminum radiator.
Dual fans encased in custom aluminum shroud and fiberglass ducting.
Renegade front pulley, motor mounts, alternator brackets, High Energy Ignition system.
Weber/Edelbrock 750cfm mechanical secondary carburetor.
Aluminum Medium rise, split plenum intake.
Fresh valve job, fresh seals. Some relieving of intake and exhaust ports (porting)
Chrome headers. +5HP... LOL
Modified Corvette dual outlet/dual exhaust.
Holley electric fuel pump.
High torque mini starter
This engine is the perfect combination of broad torque and horsepower bands for this 914.
Transaxle:
Porsche 901 with extra fast 5th gear (flipped H gear) and 1st gear deleted.
It recently began making a bearing sound but comes with 2 extra transmissions.
Kennedy Engineering Products adapter plate, flywheel, and clutch package.
Front suspension:
All 911 Carrera with Elephant Racing torsion bars (pretty firm).
Turbo-tie rods and bushings.
Bilstein struts.
Tracks straight and true.
Rear suspension:
Koni Sport adjustable shocks.
140lb hypercoil springs
Coleman adjustable height perches.
911 axles with 110mm CV's. The largest CV's you can put through stock trailing arms.
911 hubs and stub axles.
Brakes:
Front: Stock Carrera with Porterfield pads. 3.5" caliper bolt spacing.
Rear: Rotors are 911 vented and cross drilled.
Calipers are Eric Shea built spaced calipers to retain stock emergency brake with Porterfield pads.
Tires and wheels:
Porsche 996 Twin-turbo hollow-spoke alloys. 8X18 and 11X18's with Ernie's Alloy's aluminum spacers.
Michelin Pilot Sports 295-30-ZR18's in the rear and 225-40-ZR18's up front.
Body:
Sheridan rear flares. Rolled front fenders. Stock front and rear fenders. Fiberglass top.
MOMO Race steering wheel.
No accidents.
Fiberglass air damn under front fender.
Pneumatic rear trunk shocks installed.
No rust in hell hole that I can see.
A native California car.
Comes with:
2 extra working transaxles
Two front sway bars. 1 stock and another is infinitely adjustable aftermarket bar.
Extra set of front vented rotors
A 3 gauge center console with factory gauges
Two Porsche Cookie Cutter rims with Yokohama stickies.
She is a daily driver.
Reduced price for a fourth time.... Now asking $8900
Sixth price reduction..... $8500.
Seventh time..... $7800.
I'm sorry... but this is an emergency sales price and she's got to go immediately. Please don't take advantage of my situation. =-(
