QUOTE(A&PGirl @ Dec 25 2008, 01:42 PM)
So, I finally went got some price quotes on paint Monday afternoon. Will 1 gal. of paint cover the car and the bumpers or will I need more?
I have 3 choices (all within my price range):
1) Base coat/clear coat (under $300)
2) Acrylic Urethane (under $200)
3) Acrylic Enamel (under $200)
Which should I choose?
For color you will need 2 quarts. That will yield 1 gal after reducer is added. That will give you about 1 quart left over if all goes well.
Clear ? Count on the same or more depending on how well you can paint, and how nice a finish you want. 2 coats of clear is good if it lays out well. 2 quarts plus reducer and hardener
With, either single stage I would get 3-4 quarts. It's a little less forgiving to get it layed out slick. You will more than likely need to wet sand it so count on 3-4 coats. As a point of reference I got 3 quarts to do Mikes bus, and have about a quarts left for touch ups. 2.5 coats laid out pretty well, 1st coat wasn't a full coat.
Base / clear will look better with less maintenance, SLIGHTLY less chip prone, costs more
